Question about Sharp Cameras
Vox BLC-007B Focus and sharp picture quality - Sharp Cameras
Vox blc 007b
Hi gurukataria, you can use the china made DVD/CD player remote's which have same key functionalities as the Vox BLC007B had. They are easily available in electronic shops.
Feb 09, 2014 | Office Equipment & Supplies
Picture is out of focus.
Hello
If sound is ok, and picture only is out of focus, it must be due to the fault of the picture tube base card socket. Base card socket is one which connect the base card to the picture tube. It is diretly soldered to the base card, and can be desoldered it out from the base card and can be replaced with a same type.
You just open your TV, and you can find the base card, a circuitboard alongwith some components, diretly socketed to the picture tube base. Detach it from the pirture tube base. Care must be taken, not to shake sideways of any other directions. Just pull it back straight out. It may feel a little tight. Please check whether company have placed some glue on it or not. If there is glue, make it detach first by any sharp instrument like razor blade or so.
You will see the focus wire, attached to it, and remove it, resolder it out from the board, go for a same type in pin confuguration. Look for good quality material. Never insist on comapny itself. It is not a crucial component, The quality of material is more important. Ok
Nov 24, 2010 | Sony KV-32S42 32" TV
I have a 1080 with 120 and my picture is not clear. If it's not a hd channel it really is terrible and if it is hd channel it still is not in full focus. The picture is not sharp. I am really disappointed...
I am assuming your set is new. Ask for it to be serviced under warranty. This sounds like your set is defective for some reason.
LCD TV sets are known for their exceptional sharpness and performance when having a good quality signal source, and especially with an HD programs.
Jerry G.
Nov 14, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture quality terrible on Microsoft LifeCam VX-1000 Webcam
You should be able to adjust the focus by adjusting the lens.The little housing where the lens is should be able spin a bit. If you gently spin it a bit, it should change the sharpness of the image on the screen.
I hope this help you.
Oct 14, 2009 | Microsoft LifeCam VX-1000 Webcam
Hi, I have a issue with the quality of the pictures I've taken recently on my Z2, the pictures a blurry around the edges. The centre of the photo is sharp. Do you have any suggestions please of what to do,...
This is due to settings change
Please switch the focus mode to multi point focus or any other
current setting will be center focus or spot focus that is why only the center is focused and the rest is blurry
Please refer to your fuji manual for instructions on how to change the focus mode
Thanx and i hope this solves your problem
Please dont forget to rate this information
Jul 17, 2009 | Fuji FinePix Z2 Digital Camera
How do I adjust the HD quality for a crisper picture? I have tried Magic Focus, but need to know where the sharpness or contrast can be tweeked .
The magic focus function is to electronically align the red, green and blue beams. So all it can cure is colored ghosts. The contrast, brightness and sharpness adjustments are in the customer menu settings. With the remote just push menu and select video or picture adjustments. Those adjustments are in there.
Jun 11, 2009 | Hitachi 57F500 57" Rear Projection...
Enhancing picture quality
You might try taking the screen panel off, taking care to look for attached connectors. Make sure unit is unplugged before attempting this. Use a good glass cleaner to clean off all three projection lens assemblies. Do not attempt to adjust these lens, just clean them. Also clean the reflecting mirror at rear and inside surface of the screen. This should improve brightness and focus if they were soiled with dust
Jul 29, 2008 | Sony KP-51HW40 51" Rear Projection...
Picture brarred, focus responding but cant improve picture quality
did u try adjusting the focus knob in the flyback transformer? this device is connected to the anode of the picture tube which produces the high voltage so be very careful of adjusting it. dont touch the wire linking to the tube. thats approximately more than 21,ooo volts dc! good luck!
Jan 17, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
Focus problem with optio555
I think you have a defective camera. I have the 555 and none of my pictures ever look out of focus like that. Especially since those are outside with lots of light. They should be crystal clear. The colors don't look too goood either. Have you just taken it in P mode and let the camera choose all the settings? Have you possibly set some settings that have changed what the camera came with?Something is not right.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
Top Sharp Cameras Experts
Marvin
Marvin
tylerbell49
Level 1 Expert
NOEL
NOEL
Are you a Sharp Camera Expert? Answer questions, earn points and help others
