My brake light for my frontier truck will not go out after I turn off the engine. What and where do I buy a switch for the problem?
I have to take off the batteries terminal to turn the lights off and...
DON'T REPLACE YOUR BREAK LIGHT SWITCH YET...
the 98 frontier break arm (what the pedal is attached to) has a MANUFACTURED "hole" through it that will allow the plunger of the break light switch to pass right thru. There is supposed to be a rubber "button" snapped into this hole, however, over time, dry rot and age will cause it to fall out. When this "snap in" button falls out, your break lights will stay on till the battery dies. This is another shining example of DTF engineering. (design to fail) Most cars now are filled with these little parts and they're purpose is to generate revenue.
Your break switch probably works.
1. look in the floor board for the button that fell out, it's about the same size as a button off your shirt.
2 Slide your hand up the break pedal arm till you find the "hole" I'm referring to. (you'll know it when you feel it)
3 Tape the damn button back into the hole with electrical tape, or tape a shirt button over the hole. that will work for a little while.
** remember ** if you are driving with break lights in this condition (on all the time)...no one knows when you're really stopping!!!
you can get a snap in rubber grommet to replace it at most hardware stores (I don't even want to know what Nissan would charge for this little part.)
**note** replacing it is easy if you start the truck first (power breaks) and have someone hold the pedal while you work on it!
One thing is 100% for sure you will need the dealer for this repair.
