Question about Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 wont copy or fax unless i put slight pressure with my finger on the lower part of the control panel to the left of the stop/exit button or under the 0 of the keypad
I can receive a fax
I want to stop getting a copy / confirmation of every fax I send Waste of paper
To turn off the confirmation use the following steps.
1. Press MENU. 2. Press the arrow key until SETUP REPORTS then press SET. 3. Press the arrow key until TRANSMISSION or XMIT then press SET. 4. Press the arrow key until OFF then press SET. 5. Press STOP/EXIT.
Aug 20, 2010 | Brother IntelliFAX 4100 Laser Fax
It rings but wont pickup unless you pickup handset and press start fax
Your machine has the Easy Receive function. Although it's enabled, there's another setting the turns the feature ON, OFF, SEMI. To set the machine to automatically accept/print ALL faxes, do the following:
  1. Press Menu, 2, 1, 3. you will see 3.Easy Receive in the window
  2. Use the <--> keys to change from OFF to either ON or SEMI (in your case you want the feature fully enabled so change it to ON)
  3. Press Stop/Exit.
Your machine should now accept and print faxes automatically.
Oct 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Sleep mode will not disable, even when send button pushed, paper put in for fax or receiver taken off hook. Sleep mode set to default 5 minutes.
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
How do i program speed dial phone numbers into my brother intellifax 4100
Per Intellifax 4100 manual:
Storing Speed Dial Numbers
Press Menu, 2, 3, 2.
2 Enter a three-digit (a two-digit for
FAX-4100) Speed Dial number, and
then press Set.
3 Enter a number (up to 20 digits), and
then press Set.
4 Enter a name (or leave it blank), and
then press Set.
5 Press Stop/Exit.
I hope this answers your question. Thanks for using Fixya and best of luck!
Greg
Jun 12, 2009 | Brother IntelliFAX 4100 Laser Fax
Brotherintellifax4100...will not copy, send or receive fax
This might work: Press Menu, Mode, 0 to enter the Maintenance Mode. Then touch 91 to clear most of the machine's memory. (But not your phone numbers & stuff.)
More likely, that won't work, because your keyboard is messed up. These machines won't allow you to press a key when another is still down. Is one key sitting lower than the others? Or maybe water has been spilled in the keyboard? The keyboard itself might be bad. I've had to replace one only once, but it happens.
May 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax running slow
try unplugging machine. then press and hold "stop/exit" button while plugging in machine. continue holding button for 5 secs, then release. that is a procedure to clear any faxes stuck in memory.
hth,
razors
Feb 18, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother intellifax 4100 squeaks when printing faxes
THIS IS A HARD ONE, THE BEST THING THAT CAN TELL YOU IS TO LUBRICATE ALL THE GEARS IN THE MACHINE, THERE IS A SLIGHT POSIABLITY THAT IT IS COMING FROM THE FUSER MODULE
Jan 07, 2009 | Brother IntelliFAX 4100 Laser Fax
Lower Modem Speed on a Brother Intellifax 4100
You need to find a service manual. Or have you tried brotherusa.com. The settings are made through the firmware switches.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 15, 2008 | Brother IntelliFAX 4100 Laser Fax
BROTHER INTELLIFAX 4100
We also had this problem. The solution that worked is to put the machine in maintenance and reset the scanner. Unplug the machine, put your finger on the menu key first and then re-plug the line while holding the menu key, in about 30 seconds all the lights will flash and the display will say maintenance. Release the menu Key and press 55 and this will reset the scanner; if scanner error comes up the machine will need to be serviced. Press stop and then 99 this will exit you out of maintenance. If the machine does not have an error try making a copy of blank sheet of paper and see if there is any improvement.
Sep 13, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
