Ovens Logo
A
Anonymous Posted on Oct 07, 2016
I have a pelpro Warnock hersey pellet stove. will not feed pellets.
Recently moved a reinstalled pellet stove. now pellets will not feed. fan and igniter work but feed light flashes.
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Electric grill is intermittant or cuts out after 5/10 minutes
There are two overheat devices in the oven. One feeds the oven timer/programmer for the main oven and the other feeds the grill. If the cooling fan is running ok, then I would suspect it is the cutout feeding the grill elements that has perhaps with age is not working as it should do.
1helpful
Cooling fan not going round
I assume you are referring to the external cooling fan.
You need to determine that you are gettinjg power to it, if you are, then try spraying the bearings with WD40, if it still does not work, then you are going to have to replace it.
If no power, then you are going to have to trace the feed back to the control switch, and work from there .
Hope this helps.
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
1helpful
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
