Siemens Gigaset 8825 Cordless Phone Logo
Question about Siemens Gigaset 8825 Cordless Phone
I've had a Gigaset 8825 system for 12 years. Regular batteries were mistakenly used in the handset s for several years. If rechargeable batteries are used will it restore the handsets?
Posted by Stan Dziedzic on
1helpful
Our Siemens gigaset A2 keeps flashing at us and doesn't work.
First pull the battery fron the handset, pres the register button (Page) for a long time, eg 10 sec, then register the handset through the menu, setings, handset, register
2helpful
3answers
Password
Complete the following steps to reset the PIN on the 8825 back to 0000.
1. Press MENU.
2. Scroll to System Settings but do not press SELECT.
3. On the keypad, enter *65# (Star, 6, 5, Pound).
4. It will display "System PIN Reset" and return to the idle screen.
Change recorded message
Please follow the steps:
1. Press MENU
2. To select "ANSWERING SYSTEM MENU?", press SELECT
3. Scroll to "GREETINGS?" and press SELECT
4. Scroll to type of desired message and press SELECT
5. Scroll to "RECORD GREETING?", and press SELECT
6. Record a message or greeting through the base speakerphone or base station handset. 7. Press SELECT to play back greeting/ message.
NOTE: To avoid background noise, record message through the corded handset.
8helpful
Gigaset 8800 PIN reset
  1. Turn the handset off by pressing and holding the PWR key.
  2. While holding down the keys 1, 4, and 7, turn the handset back on.
  3. It will display "Handset Service".
  4. While this message is displayed, type in the numbers 4 6 8 5 4 6 3 (the word "hotline") on the number pad.
  5. The phrase "Settings Reset to Default" for a second or two and the handset will power itself off.
Note: When you turn the handset back on, the handset PIN will be reset to 0000.
Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to www.cordlessrepair.com
3helpful
3answers
System pin unknown
I will email you steps to restore factory default PIN...send me a note
Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Beeping Handsets
Mine have done that as well.
After cleaning the contacts on both the handheld unit and the base itself, it seems to stop the problem. Try using a qtip that is wet with water or alcohol.
Siemens 8825 gigset 2 line phone
If your system was working fine, and it all of a sudden started doing this, it sounds like your base has taken a surge of some kind. Your base needs replacing. You can try re-registering the handsets, but from my experience the problem is fatal. Now if this is a new installation and the handsets never work yet on the base, you just need to register them. You can download the manuals or get tech tips at Siemens website, gigaset FAQ pages.
Top Siemens Lands Phones Experts
Marvin
Marvin
Jaime Hernandez
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
