Washing Machines Logo
Question about Electrolux Washing Machines
My electrolux steam washers power button does not work, but the drum light comes on when i open the door. Tried unplugging several times but same response.
Posted by travis smith on
5 Related Answers
Anonymous
  • 3587 Answers
SOURCE: washer door latch stuck, can't open
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
Posted on Feb 10, 2008
Anonymous
  • 1185 Answers
SOURCE: 1 month old electrolux FL IQ cuts off and won't restart
If it is only one month old then you should be covered by the warranty ??
To unlock the door place the drain hose in a bowl until the water comes out, if it wont then try blowing down the hose.
If you hear bubbles inside the machine then dump the hose back in the bowl
Once the water has all ran out switch the machine programmer to "off" and then try the door
Posted on May 31, 2009
Anonymous
SOURCE: I have a Fisher & Paykel GWL11 washer. I
I have the same problem...looking for service technicians manual or some way of troubleshooting.
Posted on Jan 13, 2010
TheMobilian
Dan Webster
  • 8221 Answers
SOURCE: F21 flashes on the time screen -- am unable to power washer off
Lets see: F21 Long drain Possible cause: Clogged filter0c09ded.jpg, clogged/failed pump Remove the bottom panel299686f.jpg go for the pump cleanout, get the googus outb1cfae3.jpg. Tech sheet is located behind the white box to the left which is the motor control unit (MCU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL7b78889.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 18, 2010
ginko
Ginko
  • 19396 Answers
SOURCE: washer power button will not
Hi.
Please read the article I wrote on fault codes F70 and F71. The problem is the same with all Duet models:
F70 and F71 are two logic board error codes that point at a communication error between the main log...
Regards. Ginko.
Posted on Dec 06, 2010
Is there a way to reset the control panel without using the control panel? And is there a way to unlock the door to get my clothes out without using the control panel?
take off the top of the machine and move the drum to the rear and using a small stubby screwdriver find the lock unscrew it to get the door open eric
The door of the Kenmore Elite 4.3 cu. ft. Front Load Steam Washer won't open
Ouch. Well I believe cll is child lid lock or something to that effect is engaged. You will have to find something to manually turn the locking gear or if you have a manual figure out the watts/amps and use some type of power adapter similar to that to jump the lid lock to open. Turn it off and back on and it should begin working again. But either the door lock, the door close sensor, or the main board are faulty.
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
1helpful
I have an Electrolux ewf1090 front load washing machine, about 7 years old. Tried to turn it on. Everything seems fine, all lights and buttons work, but when I press the start button nothing happens. What...
Good Afternoon Simo, thank you for allowing me to assist you. Let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, it would be advisable to contact an experienced appliance repair tech to assist further.
1helpful
2answers
My electrolux ewf 1087 front loader door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
8helpful
Finished, wash and spin lights flashing. Door
I just had this problem! To get the clothes out, open door manually (follow answers on other threads here about opening toe panel and gently pulling down on door release). But as it turned out, I didn't need to remove the clothes, and now my washer is working again.
A local repairman gave me this advice over the phone. Make sure dial is switched to off. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. The second time I tried this, my washer worked afterwards. I've done several loads today with no problem.
1helpful
Washer door will not open. Power button will not
You can manually unlock the door on this washer. First you should unplug the washer from the wall outlet and then remove the lower access panel. With the lower access panel removed, and the washer unplugged, reach up to the door lock and feel for a round release ring and pull it down. The door should unlock now.
Thank you !!
LG DLGX8388 Steam Dryer. Controls inactive.
Make sure drive belt is not broken
Jan 29, 2018 • LG Dryers
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
