Question about TCL L32D20
My TCL TV is lock on one channell with a podlock showing only the power key is working and i have no remote
Posted by Widmark Garcia on
richie46
    Top Expert:
  • TCL Master
  • 12,962 Answers
Is there a reset button? Have you contacted customer service at TCL? Check your manual?
Posted on Oct 06, 2016
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Tcl led hdtv won't program with comcast remote
If Comcast does not list a code for your TV, your remote probably does not have a code in its library that will work.
Jan 25, 2014 | TCL 50 Class LED HDTV - 1080p, 1920 x...
Need Time Warner remote codes for a TLC TV
There are no Time warner codes for TCL tv's. You will have to perform a "code search"
1 Turn on the device that you wish to program. If you are programming a DVD or VCR player, then insert a media disc such as a DVD or VHS tape.
2 Press the device key on the remote once. This remote is capable of programming five devices, and each has its own respective button at the top of the remote. For example, if you wish to program a TV, press the "TV" device key at the top of the remote. The device key will blink once.
3 Press and hold the "Setup" button on the remote. The selected device key will blink twice, indicating it is ready to be programmed.
4 Enter "991" on the remote. The device key will blink twice again.
5 Aim the remote at the device you wish to program and press the "Power" button.
6 Press the "Channel +" button on the remote. Continue to press that button until the device turns off. Once that happens, press the "Setup" button to lock in the code.
7 Press the "Power" to turn the device back on and it will be ready to use
May 15, 2012 | TCL LE24FHDD20 24-Inch 1080p LED HDTV
TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
Oct 24, 2011 | Televison & Video
My tv is a tcl brand model tcl-14175 i accidentally on the child locked.can I have the child lock code for my tv?please
my tv is tcl model ( t1436a ) , lost my tv's remote controller , please give the model number of remote controller
Sep 24, 2009 | Tvone TV-207 Television
My TCL 2027U's child lock in on and I can't unlock it
kapag naCHILD LOCKED tapos hindi na maopen ang TV,,,pero nakastandby sya...sira na din ang remote....
anu pwedeng gawin???
please answer...
THANKS
Nov 28, 2008 | Akira EPM-420A 42 in. Plasma Television
Tv tcl-14175 no sound on channels but ok on audio video mode
Hi
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
thanks!
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
Codes for TCL TV on the Chunghop universal remote
most universal remote would work like this... press butons tv and power on at same time till red light of remote lights still. then press 110. then presto, it works... i hope i help in a way.
Jan 30, 2008 | Universal Remote Control Remote Control
Tcl tv 2913n
Simultaneously press “DISPLAY” button on remote handset and Volume- button on the front panel of television receiver for 6 to 8 seconds to get the various service menus. · To access any parameter , use Up/Dn keys of Program/Channel
· To change value of any Parameter, use +/- keys of Volume
· To exit POWER switch off the set
Aug 29, 2007 | Thomson 20LCDB03B 20 in. Television
TCL L32D20 Logo
309 people viewed this question
Top TCL Televison & Video Experts
Lawrence Oravetz
john h
Are you a TCL Televison and Video Expert? Answer questions, earn points and help others
