Question about Panasonic Viera TC-P55UT50 55" 3D 1080p Plasma TV - 16:9 - HDTV 1080p
Panasonic TC-P55UT50 plasma went black. power light blinks 7 times, pauses blinks 7 times. Is this a power board? or Y-Sustain?
We were talking, turned around and have black screen. Unplugged, checked all cables, etc. as stated above the power light blinks 7 times, pauses and then blinks seven times and continues this.
Posted by Mike LaFollette on
    Top Expert:
  • Panasonic Master
  • 76,407 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Oct 07, 2016
Samsung 37A550 TV screen went black
check connections. then, separate wiring. touching wires creates cross-talk of signals.
Jan 15, 2014 | Computers & Internet
While viewing my 50 inch Panasonic (2 yrs old), it clicked and turned off. The pilot light blinked 7 times, paused and continued to blink 7 times, pause etc. That's it. It will not turn on. I look...
7 blinks Driver SOS 2 SU / SD / SS Boards. (SC floating voltage area)
This is the fault. 7 blinks of standby light denotes it. If you wish to get more details about the blinking codes to Panasonic TVs, check the site
linked here. It has details and some troubleshooting hints. google.com/+GopakumarGopalan
Nov 25, 2013 | Panasonic Televison & Video
Panasonic viera th-50pz800u won't turn on. Red power light blinks 10 times.
thats a sos error for numerous supply voltages missing. Send a email to me for assistance as I cant post the info here [email protected]
Apr 01, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
The tv just turns off after about 5 seconds and won't stay on. i've used the system reset and unplugged it already. no power surge, lightning storm, etc. Ideas?
If reset does not cure it and if after about 70 seconds of unplugging set the green power light stops blinking, do this:
When power light comes on and goes off, on the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and RELEASE both buttons.
Power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code you find and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Dish washer 665.13824k601
LOCK LIGHT STAYS ON AND WILL NOT START. I HAVE TURNED THE POWER OF AT ELECTRICK PANEL AND IT STARTED ONE TIME. BUT DID NOT START ANYMORE.
HELP
Nov 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Hitachi power light blinking
Does anyone know how to fix this very common Hitachi problem without paying a repair man? And if you did pay a repair man did they fix the problem, and how much was it? I absolutely LOVED this TV before this happened. :(
Jun 21, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Blue power light blinking 3 times
I am having the same problem, what was the solution to this problem? And how much did it cost to fix it?
Jun 21, 2008 | Hitachi P50T501 50 in. Plasma HDTV
Panasonic Viera TC-P55UT50 55" 3D 1080p Plasma TV - 16:9 - HDTV 1080p Logo
301 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
