SOURCE: Sony MHC-RV888D - TAPE Recording to Laptop as mp3
on laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
SOURCE: sony mp3 MHC-RG440s
well fuses are at the power supply sections and if the tape was jamed inside the deck, just disconnect the plug and try to take-off the case/cover of your unit but before opening it wait for about 1-2 hours to discharge the capasitors and then disassymble your unit try to get the tape deck and then get a knife a scissor, something to cut the tape inside the deck, thats the best solution, but you won't get your tape back though even when you get your tape uncut well, when you play it again you will not get good sound.
maybe your tape deck have a problems, maybe a broken gears, a belt was snaped, or a relay is the main problem.
its better to observe your unit first before you play a tape again.
ok? hope you could get your system back in good condition and have a good day.
SOURCE: Sony compact disc player initializing
Have you tried pressing hte RESET switch?? It's behind the removeable front of the stereo, use a biro or something and hold it in for a bit.
Failing that, check that there isn't a CD already in it, could be a dodgy CD?
SOURCE: my sony MHC-GX450 has power but does not function,
Mine did the same thing. I unpluged , and carfully took top off where I found a CD stuck. I carefully rermoved CD and put back together. When I plugged it back in I heard a click and the display lit up and I was good to go. I might have just lucked out.
SOURCE: Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
