What is the greatest common factor of 14, 42,and 56
Posted by Alisonjbair on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
The greatest common factor is 14.
Posted on Oct 06, 2016
paulgbrandon
  • 654 Answers
Greatest common factor of 14, 42, and 56.
Factors of 14 : 1, 2, 7, 14
Factors of 42 : 1, 2, 3, 6, 7, 14, 21, 42
Factors of 56 : 1, 2, 4, 7, 8, 14, 28, 56
What is the highest factor, in all three (which makes it common) : 14
Good luck,
Paul
Posted on Oct 08, 2016
What is the improper fraction of 2/10
I think you want to reduce the fraction to the lowest terms.
Improper fraction 1 3/4 produces an improper fraction of 7/4 (1 times denominator plus numerator)
To reduce a fraction, we need to divide the numerator (number on top) and the denominator (number on the bottom) by the greatest common factor (GCF).
To get the GCF, find the factors of the numerators and denominators and find the greatest number that is in both lists.
The factors of 2 are 1, 2.
The factors of 10 are 1, 2, 5, 10.
The greatest (largest) number is both lists is 2, so we divide the numerator and denominator by 2 and get 1/5.
Good luck,
Paul
Feb 06, 2018 | Homework
Greatest common factor of 27,63
9 is the greatest common factor and 189 is the LCF.
Oct 11, 2017 | Office Equipment & Supplies
-54k^2+3k
-54k^2+3k I assume that you want to factor this completely.
I do it one component at a time.
What is the biggest common factor of -54 and 3. I use a trick of adding the digits of the number. If 3 and/or 9 go into that number evenly, than 3 and/or 9, respectively go into the original number. In this case, 5+4 = 9 and since 3 goes into 9 evenly, 3 goes into 54 evenly. Since the factors of 3 are 3 and 1, this must be the greatest common factor of this component.
Onto the next component, what is the greatest common factor of k^2 and k. The answer is k, because k^2 doesn't go evenly into k.
Combining the two, the greatest common factor is 3k.
Next we have to divide 3k into each term.
3k(-18k+1) or -3k(18k-1)
Good luck,
Paul
Mar 29, 2017 | Homework
59 over 100 in simpilist form?
59/100 is in the simplest form.
it can also be written in decimals, that is 0.59
Jan 04, 2017 | Homework
What is least common factor
Normally, we look for the greatest common factor and the least common multiple.
To find the least common factor, we have to factor both numbers and see what the least common factor is. However, we know the one set of factors for every number is itself and one. For example, 56 and 49.
The factors of 56 are 1, 2, 4, 7, 8, 14, 28 and 56.
The factors of 49 are 1, 7, 49.
What is the least common factor of both numbers? 1
So the least common factor of any two numbers is 1.
Any questions, let me know.
Good luck,
Paul
Jun 01, 2016 | Office Equipment & Supplies
How can I simplify a fraction after adding two fractions?
Factor both the numerator and denominator, and then divide both the numerator and denominator by the greatest common factor.
For example, 1/3 + 1/6 = 2/6 + 1/6 = 3/6. We have to simplify 3/6. The factors of 3 are 3 and 1. The factors of 6 and 1, 2, 3, and 6. The greatest common factor is 3. Dividing the numerator and denominator by 3 results in 1/2.
Good luck.
Paul
Nov 23, 2015 | Texas Instruments TI-84 Plus Calculator
Greatest common factors
Please the reformulate the problem(?) with more care. Capital P is a different entity than p. Are you trying to factor out the polynomial (an algebra problem where the Greatest Common Factors have no meaning), or are you trying to find the GCF of certain positive integers (an arithmetic problem)?
Feb 19, 2014 | Computers & Internet
Highest common factor
Math is fun has a great article on how to find the GCF of two numbers:
http://www.mathsisfun.com/greatest-common-factor.html
To find the common factors, you have to list all factors of both numbers:
96: 1, 2, 3, 4, 6, 8, 12, 16, 24, 32, 48, 96
124: 1, 2, 4, 31, 62, 124
Oct 21, 2013 | Android Apps
What are the greatest common facters of 11 and 10
None of the above. The greatest (and only) common factor of the two numbers is 1.
Mar 21, 2013 | Office Equipment & Supplies
183 people viewed this question
Marvin
Marvin
