Question about Wharfedale Audio Players & Recorders
I have a Wharfedale sub-woofer model SW150 that has just stop making sound. The red light on the speaker is glowing thats all, help, Mike.
Posted by Michael Laba on
richie46
    Top Expert:
  • Wharfedale Master
  • 12,962 Answers
Blown amp on sub woofer.
Posted on Oct 06, 2016
Marvin
    Top Expert:
  • Wharfedale Master
  • 85,239 Answers
I agree with richie46
Wharfedale sw150 amplifier circuit diagram
the wharfdale SW150 is a subwoofer (hence the SW for Sub Woofer) , not an amp
try again
Feb 25, 2015 | Audio Players & Recorders
Manual to connect sw8 sub
The SW8 and SW150 have line level and speaker level inputs. It has a line level output, which will not drive speakers without using a separate amp for the signals.
Jan 20, 2015 | Wharfedale SW150 Subwoofer
Apart from the "line input"
input and output are for low level ( as with RCA cable connectors) ,, the speaker connections are for high input, (red and black connections. ) you can run the mains to the (rca) from your receiver to run the sub woofers, and from that use the speaker wire connections, to go to the left right speakers, (out only not in) this is done if you want to run the subs and the Rt/lt/ speakers , eliminating the speaker connections coming from the receiver. which you could use for 2 additional speakers if you want
Apr 23, 2011 | Wharfedale SW150 Subwoofer
It lights up but does not produce any sound,thamks
Possible that the fuse has blown or the power amplifier is defective. you will need to remove to check even to check the sub woofer coil for continuity - if the coil has opened up or is damaged.
Mar 08, 2011 | Wharfedale SW150 Subwoofer
Can I connect my floorstanders to wharfedale sw150 without any external amplifier, If so, how ?
What 'floorstanders'?
Its internal amp is for its own subwoofer ONLY, but if you use your own amp's full-range speaker-level outputs to feed two chanels entering the sub you can tag the 'floorstanders' onto the sub's speaker terminals as speaker wire extenders. Your amp will be powering the floor units.
I'd keep the sub separate and feed it LFE only if it was mine.
Feb 02, 2011 | Wharfedale SW150 Subwoofer
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
430 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
