Computers & Internet Logo
Rick Beller Posted on Oct 05, 2016
Where the power button attaches in the motherboard of a toshiba satellite c650 laptop?
5 Related Answers
kriegen69
  • 121 Answers
  • Posted on Nov 25, 2009
SOURCE: Toshiba Satellite L305-S5900. No power indicator light.
sorry there is no fuse that i know of on the satellites it sounds like a motherboard issue see if it can be warranty repaired by the manufacturer
Anonymous
  • 185 Answers
  • Posted on May 25, 2010
SOURCE: from where we download laptop drivers for toshiba
you can go here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
I apologize I'm not able to give you the exact location for the drivers but the model that you are providing does not match the database so, go to the website and check the model on the label of your computer (on the bottom) you should be able to find it here.
if it works for you don't forget to rate me
thx
Anonymous
  • 2296 Answers
  • Posted on Dec 29, 2010
SOURCE: i have toshiba satellite c650 laptop but laptopb
To reset the BIOS read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Anonymous
  • 4889 Answers
  • Posted on Jul 05, 2011
SOURCE: Hy i have a question..i want to buy a laptop and
Definitely the C660-12 as it has the i3 Quad core whre as C650EP is core 2 duo(dual core). Perfformance wise C660 -12 is a lot better.
Anonymous
  • Posted on Aug 07, 2011
SOURCE: I purchased Toshiba Satellite Pro
DOWNLOAD SOUND DRIVE TOSHIBA LAPTOP SATLLITE PRO C650 MODLE PSC11G 003001
How do you remove the keyboard on a Sony Vaio laptop PCG-7192L
Let's see if this helps Tom,
1) http://laptoppartstore.weebly.com/replace--remove-sony-vaio-vgn-nw-keyboard.html
2) http://www.youtube.com/watch?v=8BEcX_0KYIE
The Keyboard Cable STAYS attached to the Keyboard.
It disconnects FROM the motherboard's connector.
The Keyboard Cable has NO connector on the end. It is a FFC.
Flat Flex Cable.
One example of a Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
The flat metal terminal bars MUST be aligned back in the SAME position, as they were originally.
For this reason you may wish to take a Sharpee marker, and make a mark on one side of the cable.
Then make a matching mark on the same side of the motherboard connector, BEFORE you remove the cable.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two pieces, but does NOT come completely apart!
The bottom part is larger, rectangular shaped, and is stationary to the motherboard.
It is the BODY.
The upper part is smaller, rectangular shaped, and is movable.
It is the Locking Bar.
ACCORDING to the video the Locking Bar is the Slide/Wedge type.
DO NOT use a metal tool as shown. One slip, and you can damage the motherboard! Geez!
Use your Fingernails, or Thumbnails.
The Locking Bar slides up. Up towards the LCD screen, or away from the Body.
It ONLY moves about 2mm. That is a little larger than 1/16th of an Inch.
IF, the Locking Bar is broken, or the Body, you are looking at
-> MOTHERBOARD REPLACEMENT!!
Hence why I am being so detailed.
More detail on unlocking this type of motherboard ZIF connector,
A) Locked position;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
B) Unlocked position;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
There is another style of Locking Bar used, however.
The Locking Bar flips up to a 90 degree position, or also can be stated as Straight Up.
Just to make sure I'm going to include info for it too;
A) Locked position
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
For additional questions please post in a Comment.
Regards,
joecoolvette
1helpful
How to restore factory setting of toshiba satellite pro c650.note that laptop bought without os preinstalled and oem os has been installed.pressing zero key does not work.i can not select bios option as my...
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Where can we replace the battery of toshiba satellite c650 in uae
Buy the battery off ebay.
http://www.ebay.com
When the site comes up just put in Toshiba Satellite C650 battery.
Toshiba Satellite C655-S5125
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
11th heading down - Satellite A10. (A10 in Blue)
Go down to the second line, (Begins with A350D in blue), and click on -
C650. (You can also click on C655D )
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
Now what is the problem? Post in a Comment.
1helpful
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
How to take shell off toshiba c655-s5049, i need to reset mother board
Pictorial disassembly guide for the Toshiba Satellite C655 and C650 series of Notebook PCs,
You can click on each photo one at a time, to enlarge.
Advisement:
1) Observe Anti-Static Precautions
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
I suggest you buy, and wear an ESD wrist strap, and connect it's alligator clip to a good ground source.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an empty desktop computer case.
If your table you're working on has metal legs, connect to an unpainted surface on one of them.
Barring none of the above applies, at least place a large metallic unpainted object on the table, and connect to it.
Perhaps a metal serving tray, or metal (Unpainted) knickknack.
2) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
If no multi-compartment container is available, use a clean egg carton.
label each egg holder.
Some screws look VERY similar to other screws.
Do Not mix them up.
What do you mean by reset motherboard? If your thinking is that you are going to remove the CMOS battery for a while, then reinstall it to clear a BIOS password, this = no.
There is a capacitor on the motherboard which keeps enough residual power, so that the BIOS password stays in play, even with the CMOS battery removed.
(The CMOS battery is referred to as the RTC Battery. Real Time Clock battery.
As soon as the Keyboard is removed, it is right there on the motherboard. Uses the same battery holder as a desktop computer, and it looks to be a CR2032, just like a desktop CMOS battery )
There are two pads which are shorted across briefly, with a small flat tip screwdriver.
Usually rectangular in shape, and each approximately the size of a BB.
This drains the residual power from the capacitor.
Location? Dunno
Generally under a small piece of Mylar plastic sheet, and sometimes under the Ram Memory modules, or under the wireless module.
Also, this link has a free Service Manual,
Under the Toshiba main heading scroll down to the subheading that begins with -
Satellite A10.
Go to the second line in this 'paragraph', and scroll across to C650.
Left-click on C650.
(You may also want to take a look at C655D)
After you click on the file name C650, it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
Regards,
joecoolvette
2helpful
I have toshiba satellite c650 laptop but laptopb locket with power on password so please guide me how to reset password on toshiba satellite c650 password
2answers
I want all the drivers of Toshiba Satellite Pro c650. Please its urgent. Thanks.
Please visit http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Communicate
Select the Downloads
This is how you need to select your model number and then select the operating system you have in your system.
Then you will get a list of drivers for your laptop.
Regards
Anand Sachan
3answers
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. [email protected] for any additional questions.
2answers
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
