Question about 2004 Chevy Silverado - 1500, light-duty, extended cab - Molded Dash Cover
Where is fuse box location for trailer wiring?
Fuse box for trailer wiring no power too trailer plug
Posted by Chuck Roberts on
  • Chuck Roberts
    Chuck Roberts Oct 05, 2016
    checked under hood fuse box and inside driverside door fuse box
Richard Warren
    Genius:
  • Coverking Master
  • 2,548 Answers
No fuse box for trailers ,just vehicles fuses.
Posted on Jan 25, 2017
Trailer wiring
OK ON SOME OF THE TRAILER BRAKE PLUGS ( THE PLUG FROM BRAKE BOX TO TRUCK ) THE POWWER WIRE IS IN THE WRONG PLACE ,THE PIN AT TRUCK SIDE MAY NEED TO BE MOVED IN THE PLUG,
Feb 05, 2014 | 2001 GMC Yukon XL
I have a 2005 ford f550 with factory brake controler & factory trailer wire plug. On the trailer wiring plug I am not getting power to the turn signals or brake lights. The turn signals and brake...
There is a fuse box under the hood that has the fuses that control the wire harness. There are at least 2 boxes, mine were on the drivers side wheel well near the rear of the engine compartment.
Nov 14, 2013 | 1997 Ford F150 Regular Cab
No power to the trailer and fuses under dash check okay
Had that problem on my Jimmy. Turns out there was a short in the trailer wiring and it blew a small fuse that powers the trailer pigtail and my licence plate lights. It was located in the fuse box / power distribution box under the hood. There are 1 or 2 of them in there, you should be able to locate the box fairly easily, they are almost always plainly marked. Mike
Jun 14, 2011 | Ford F-250 Cars & Trucks
We just hooked up our Ford 1996 econoline van to a trailer. The trailer brakes are not working. We checked all the fuses - all seem to be fine. The fuse diagram on the fuse box panel does not tell you...
First thing is your van equipped with a trailer brake controller and is it working. This is usually a small box that is installed inside the vehicle and is needed to operate the brakes. Next what type of plug do you have on the vehicle to plug the trailer into some plugs do not support wiring for trailer brakes. If you have a aftermarket trailer brake controller it will not be fused in the fuse panel so you will to locate a inline fuse used to power up the controller. Hope this helps.
Mar 04, 2011 | 1996 Ford Econoline
I hooked up a trailer to my 04 dodge 2500 (5.7 ltr) and when i plugged in the lights my truck lost all running lights and tail lights. headlights still work and so do turn signals. I checked all the...
your vehicle has a "integrated power module". its a fancy name for a smart fuse box. What likely happened is there is a problem with the trailer wiring. The power module detected the fault and shut down the running lights. The power module will need to be reset at the dealer.
Fuse 15 is a 50 amp fuse for the park lamp relay
Fuse 32 and 34 are 10 amp fuses for the right and left park lights
Fuse 33 is a 10 amp fuse for the trailer park lights.
After it is reset I would not plug in the trailer until the fault is located and repaired.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 12, 2010 | 2004 Dodge Ram
Where is the fuse located for the 12 volt power on the trailer plug connection. This is a 2500 HD with trailer package
Hi, the power terminal to the 7 way , is not hooked up from the factory. In order to hook this up, you must locate 2 wires under the hood. The 1st wire, is between the driver fender, and the fuse box. This wire is red , and taped up. Grab hold od this wire, and pull it out of the tape. It has an eyelet on the end of it. The next wire is below the steering column, same scenario, red wire, with an eyelet, pull this out of the tape, route both wires to the front of the fuse box (underhood), take the cover off of the fuse box, you will find 2 silver threaded dtuds on the front of the fuse panel. 1 larger than the other.route these 2 wires to these two studs, and secure with 2 metric nuts. You will have to get these. does not matter which wires go where, as both studs are battery power, and are both fused. the wires will only go on 1 way anyway. after the nuts are tightened, reinstall the cover, and you will have power at the 7 way. Good luck...
Sep 23, 2010 | 2007 Chevrolet Silverado 2500HD
Right side trailer brake light does not work
Did yo check the fuse panel inside the truck its located on the drivers side dash , you have to open the driver side door, in there is a 10 amp fuse that is linked to rt trailer brakes and rt turn signal for the trailer, if the fuse is good there is a black box under the dash located on the floor on the driver side, just to the left of the break, thats where must of the plug in wire harness is for the trailer breaks!
May 31, 2009 | 2005 Chevrolet Silverado
Trailer harness - Red wire has no power
Hi: under the hood in the power distribution box there is a 40 Amp fuse that has to be installed to power up the trailer package. When standing looking from the front left fender it should be at the front right corner, refer to the power distribution diagram on the cover. As well under the box by the spare tire is a plug in type module mounted on the frame. There should be 2 wire harnesses located there, make sure the correct plug in is connected. Hope this helps... please rate suggestion .... ty
Apr 28, 2009 | 2005 Chevrolet Silverado 2500HD 2WD
LEFT TRAILER TURN SIGNAL DOES NOT WORK
I have seen once before that the fuse box was bad on a 2003 Dodge 3500. I had power in and nothing out. We had to replace the box. Not cheap! Hope it is simple like a loose connection though. I think I had to pull the inner fender on the drivers side to access the bottom of the fuse box. Pain in the ****, but...
Feb 25, 2009 | 2004 Dodge Ram 2500
Fuse blown to right turn signal when hooking up utility trailer
fuse is underhood in power dist box.
if you only blow when hooked to trailer it is a problem with trailer wiring or light
Aug 22, 2008 | 2004 Chevrolet S-10
2004 Chevy Silverado - 1500, light-duty, extended cab - Molded Dash Cover Logo
182 people viewed this question
Top Coverking Vehicle Parts & Accessories Experts
gbob59
Lawrence Oravetz
Nicola Conroy
Are you a Coverking Vehicle Part and Accessory Expert? Answer questions, earn points and help others
