Question about Makita 2705 10" Table Saw
What is the purpose for the hook plate and spring in the Makita 2705x1 table saw
5 Related Answers
Anonymous
  • 23 Answers
SOURCE: need owners manual for makita 2703 table saw..
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/
Posted on Nov 28, 2008
Anonymous
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
Anonymous
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Posted on Oct 20, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: I just acquired an LS1011 Makita saw. How does
unscrew the handle in the front to change, also I would recommend going to Makitatools.com and typing on your model number to download a users manual for this tool, it would be helpful to get the most out of it.
Posted on Oct 25, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: how do I install the spring after changing the
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Posted on Jan 19, 2010
Jm27000300 instruction manual
I suspect you may find instructions on this webpage for combined table/stand and saw as pdf download
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?Name=2705X1
I can download the manual from this webpage but Fixya does not allow document attachments.
19.August.2014
What is the spring for in the 2000w makita circular saw
Other than carbon brush springs, the only other spring that I know of on a circular saw is for the blade guard so that it will automatically return to cover the blade after you make the cut. There should be a hook or a bend in each end of the spring and each end has a certain spot where it hooks so that it pulls the blade guard back in place.
Jul 13, 2014 • Makita Saws
11helpful
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
I have a Makita LS 1013 compound miter saw. The locking knob that locks the saw from sliding back and forth no longer works. I downloaded the owners manual and parts list but I can't seem to correctly...
check position 79 the spring that pushes against the table and also the end of the locking knob to make sure not rounded over/worn not applying pressure to the locking spring.
What is the most efficient way to remove and replace the switch on the Makita 2703?
there is only one way that I know of. Unplug tool and lay on its backside to expose the undercarriage of tool, remove the screws holding the switch plate on and remove box
I was using my saw and the large spring popped out, how to reinstall it (makita dual bevel compound saw)
just found the problem, if you haven't fixed it yet let me know. There is no good way to reinstall the spring but I have done it numerous times and can talk you thru it, but you will need a press of some sort.
Gaurd will not release up smoothly, the gaurd will hit the table top not alowing saw to complete cut
for what brand and model, if this is a Makita the link bar and the plate that it rides on are possibly worn and need lubrication or replaced, also check the bolt holding the guard in place to make sure fully seated and tight Let me know and I will try and help.
3helpful
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Table Saw blade
Did you remove the center plate? It has to come out before you can remove the blade. Also make sure that the saw is unplugged before you go any further. If you still have questions contact me and I will do what I can. Also if you would like you can download a schematic of this tool at Makitatools.com just type in your model and look at the schematic. Good luck
Jan 03, 2009 • Makita Saws
Makita 2705 10" Table Saw Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
