Panasonic KX-TG1033S Cordless Phone Logo
Hugh Saussy Posted on Oct 04, 2016
Incoming calls do not cause phone to ring-everything else ok
Tried to call from separate phones- realta
  • Brett Duxbury
    Brett Duxbury Oct 04, 2016
    Hi Hugh Saussy, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    what else is plugged into phone line ?
    what was plugged into phone line before this phone was added ?
    Has it ever had the ringer ring on incoming calls.
    Do you have another phone you can use to test the phone line to see if it rings ?
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 09, 2008
SOURCE: Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Anonymous
  • Posted on Jan 29, 2010
SOURCE: Incoming calls only ring once then hangs up. Can call out/not in
reset your mobile
Anonymous
  • 3 Answers
  • Posted on Sep 15, 2010
SOURCE: I have PBX Tes824, Main phone kx-t7730 When it
to ring only at extension 101 and 106,you can do this press *# 1234# press 408 speaker phone CON. press * CO1. Enable press right arrow key from 7730 phone CO2. mixed CO3. mixed CO4. mixed CO5. mixed CO6. enable press Auto dial store thats it
pishta68
Steven Wander
  • 599 Answers
  • Posted on Oct 19, 2010
SOURCE: my panasonic phones do not ring when an incoming
Ringer turned on? quite common and I'm a phone repair man. Does the calling party hear multiple rings? If it rings only once and goes to silence on the calling party end, there is a high resistance short on the line and it must be repaired.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Dec 02, 2010
SOURCE: Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Phone does not ring
Time to get new phones. You incoming wires are not operating on the base of the phone. It is called the 'ring-side' or 'red' wire. Unless you know where the break is, you cannot fix it. because it happens on all the phones....it has to be broken in the base that serves them all. This isolation is furthered by the fact that a corded phone works fine on incoming calls, so it is not in the line to the building, broken on the ring side that is. Happy phone hunting!
blkqueentech
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
2helpful
Landline phone does not ring out when there is an incoming call
incoming calls ringer on corded land line phone no longer works
3helpful
On incoming calls all it does is vibrate
social.microsoft.com/.../8306e39b-6e42-4db0-a318-36fd49d59601
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
1helpful
Ring voloume
ave you set it from inside the profiles for incoming calls. have you turned up the volume from the side of them phone when making or recieveing calls. set your pofile with all the loud tones and then it should work again.
2helpful
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
1helpful
Samsung SCH-u740 incoming call ringer volume
Have you tried this? With the phone open, using the side key next to the charging port to adjust your volume then pushing OK to set it before closing the phone.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
