Question about RCA RCR504BR 4-DEVICE PALM-SIZED UNIVERSAL REMOTE
Need a code for my tv its a tecnicolour by rca none of the rca codes would work and the auto code search didnt work either :
Need codes cause the manualy codes and the auto code search both did not work my tv is a technicolour by rca
Posted by dustin austin on
FRED ALBRIGHT
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
I have a different model of RCA but had the same problem, try this: Code for Comcast Remote Control is 13183
Code for Voice Control Remote Control is 12292, however when you go thru the automated process of programming your TV you need to select TCL as your TV brand. Do not select RCA for Voice Control Remotes.
Posted on Oct 03, 2016
RCA RCRHO2BR codes not working with Sansui TV
You may have to try a different URC. All URCs do not contain all possible codes.
May 05, 2018 | RCA Televison & Video
All the codes in the manual dont work with my rca tv you know what i can do to fix it?
Eric, most universal remotes have a auto search feature, it should be in the remotes manual. If you have no manual try Google search your make and model# manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://voxrightnow.custhelp.com/app/answers/detail/a_id/1569/~/automatic-code-search-method-for-universal-remote
RCA Remote Auto Code
http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button
May 17, 2016 | RCA Televison & Video
I need codes for a remote control by rca?
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 17, 2013 | Televison & Video
Forgot how to manualy code search on rca remote
[edit]Steps Turn on the target device, your VCR, DVD TV etc.
  1. Press and hold code search until the LED lights up.
  2. Release the code search button.
  3. Press and release the component button you wish to program. When this is done the indicator light for that component will blink and then remain steadily lit.
  4. Press and hold the code search button until the correct code is found. A new code is sent every three seconds. This can take a while.
  5. Aim the remote at the target device and press on-off on the remote until the component turns on.
  6. Press Enter to save the code.
Mar 13, 2009 | RCA Universal Remote Control
RCA RCR311B Remote Control
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie TV) while holding TV press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Oct 26, 2008 | RCA 3-Device Universal Remote
Converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
2: press and hold the component key (ie SAT while holding SAT press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
Hope this works
Oct 07, 2008 | RCA 3-Device Universal Remote
Instructions for using the code search on the remote
RCA REMOTE controll
I have an RCA Direct tv remote that does not show any buttons for codes. crk 78sg4 XX15472-168 01505 k7d
I would like to know what codes to set and how so that it can work with my TV and my VCR.
Please write to [email protected] Thank you.
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Dec 04, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
RCA RCR504BR 4-DEVICE PALM-SIZED UNIVERSAL REMOTE Logo
93 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
