Question about Sharp MX-2700N Color Copier
Upgrade sharp mx-2700n firmware
My machine is displaying E7-09 error, i was told to upgrade the firmware.
Posted by EZEKA on
5 Related Answers
Anonymous
  • 24 Answers
SOURCE: error code h4-01
P * C * enter sim 14 press copy key then CA. Machine should reboot. if problem re-occurs your thermostat in the fuser has tripped
Posted on Dec 01, 2008
Anonymous
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
Adorjani Laszlo
  • 1316 Answers
SOURCE: What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Posted on Aug 02, 2009
rezazadeh
abbas rezazadeh
  • 328 Answers
SOURCE: Sharp MX-2700N how can I clear maintenace code CA?
enter code 20-1 start
Posted on May 27, 2010
salimrangwal
  • 9 Answers
SOURCE: after installation my sharp ar-m420u
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Posted on Jan 16, 2011
How do i upgrade firmware of sharp mx2700n copier
To update the firmware, set DIP SW 2 on the MFP control PWB to ON.
1) Insert the USB memory into the machine.
* When USB is not connected, "INSERT A STORAGE FIRMWARE STORED ON" is displayed. When [OK] button is pressed, the display is shifted to the folder or file selection screen.
2) When a firmware update folder or file button is pressed, the display is shifted to the firmware update screen.
* The number of buttons depends on the number of files in the inserted USB memory.
A folder name or file name is displayed on the button.
If the folder name or file name is of more than 34 characters, only 34 characters are displayed.
For a folder name, "<DIR>" is displayed at the head.
* When [ .. ] button is pressed on the file selection screen, the display is shifted to the folder or file selection screen. On the folder or file selection screen, the keys are disabled.
* The path of the folder or file is displayed on the title section.
If the path is of more than 50 characters, only 50 characters are displayed.
Read more >> http://electrohelponline.blogspot.com/
Aug 19, 2016 | Sharp MX-2700N copier
How do I remove Error code L4-02
L4 errors relate to motors. L4-02 specifically means Paper feed motor locking trouble.
You will need to take it in for repairs.
Nov 05, 2015 | Sharp MX-2700N Color Copier
My Copier Sharp MX-2700N displays print quality Automatically adjusted and it wastes so much time to initialize. How do i fix it?
might also be the it has to have its firmware re-flashed have tech come and check it out and have a good cleaning done.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 12, 2015 | Sharp MX-2600N Laser Multifunction Printer...
We have a code h4-30 on a sharp mx-2700n how do I reset?
You need to make sure the machine is in Copy Mode when you hit
# * C *
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jul 07, 2014 | Sharp MX-2700N Color Copier
Sharp mx 2700n how to go SP mode and i get error code h5.01 how i solve this problem
Use SIM14 to
cancel the trouble.
Entering the simulation mode
1) Copy mode key ON → Program key ON → Asterisk (*) key
ON → CLEAR key ON → Asterisk (*) key ON → Ready for input of a main code of simulation
enter 14
accpet yes clear..
machine should restart.
You may have to have a tech look into why this is jamming...
Hope that helps
Lbcoaster
Dec 23, 2008 | Sharp MX-2700N Color Copier
Error code h4-01
Dec 01, 2008 | Sharp MX-2700N Color Copier
Sharp MX-2700N Color Copier Logo
139 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
