Reebok Rl525 Elliptical Resistance RBEL79020 Logo
cnorini Posted on Oct 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What size rechargeable batteries for the 6 AA's in the RL525? 1.2V? MA size?
The Vanguardian
Level 3:
Master:
  • Master 531 Answers
  • Posted on Oct 03, 2016
The Vanguardian
Master
Level 3:
Master:
Answers
531
Questions
0
Helped
180649
Points
2974
From reading others that have fixed this, it is simple NiMH rechargeables at 1.2v, not lithium.
As long as you have a matched set of batteries, the MAh won't matter. Usually the higher the better, it will take longer to charge and discharge and they will last longer (years). I suggest around 1800MAh or better, they don't cost that much more than 1200MAh.
People have wired in battery holders in place of the battery pack, to make it easier to replace next time.
Be sure and recycle your old batteries.
Whats the voltage maximum on the cobra walkie talkies
Most lithium small radio batteries are 3.6 volts. If AA or AAA batteries, multiply by 1.5 volts. 4 batteries = 1.5 * 4 = 6 volts MAXIMUM. Rechargeable batteries are 1.2 volts. Your charger would be a much higher voltage because it takes power to "push" the charge into a battery. You didn't say, so I am assuming you want to operate the radio with a wall charger. I've done this by soldering the wires to the battery contacts. You need a higher voltage than 3.6 volts, but milliamps is more important. You need enough milli amps to get the radio to transmit. Too much and it frys, literally. So, this is all on you to decide if the risk is worth it. I use a 5-6 volt power supply set on no more than 1 amp (800 ma is my favorite size) 1 amp = 1000 ma. Let us know if this helped!
What type battery for powershotA480
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
1helpful
On?Off switch failure
Not sure the A3300 has two AA sized batteries, but if it had:
Sure your batteries are still tip top?
Try two new AA sized NiMH rechargeable batteries or if you have some new alkaline batteries, put them in. the alkaline batteries won't last long, but it it could hint if the camera is still working and worth buying new rechargeables.
AA manganese (Zinc-Carbon) batteries cannot be used with this camera.
But even if it has one battery, check the battery.
Read other parts about batteries, in other help text I wrote for other users.
6 AA Batteries generate how many amps
If this is a battery powered CD player,
we are talking mA not amps.....6 x 1.5volt batteries give you 9 volts
I would recommend something like this:-
http://www.ebay.co.uk/itm/New-AC-DC-Universal-Travel-Adapter-Input-110-220-Volt-7-Output-500mA-/251316939793?_trksid=p2054897.l4275 This will have more than enough power for the CD Player.
2answers
Does powershot A470 use AA rechargeable battery?
Yes. You can use either rechargeable (NiMH) batteries or disposable (alkaline and lithium) batteries.
Does this camera operate on regular AA bateries. Put 2 brand new ones in and it will not power up. The manual says Kodak does not "support" Alkaline batteries....
Probably this old chat may help you to resolve your problem.
From site:
http://www.digitalcamera-hq.com/products/kodak-easyshare-c663
Kodak EasyShare C663 Specifications
  • 6 megapixels
  • 3x optical zoom / 5x digital zoom
  • autofocus
  • auto exposure
  • JPEG file format
  • ISO 100-400
  • 2 AA batteries
  • movie mode w/sound
  • 2.5" LCD screen
  • Part Number:C663
  • Release Date:Jan 12, 2006
chrissy66 (12/10/2007)reply to this comment (by James DeRuvo - 12/12/2007)Sounds to me like your lens may have come out of alignment. Was it dropped recently? Since your camera is still under warranty, the best thing you can do is have Kodak should fix it. If your camera is out of warranty, or if Kodak refuses to repair it for free, the one thing you can try is to try resetting the camera.
Kodak is also of the opinion that lens errors also occur when you use batteries not recommended by Kodak.
I recently chatted with a kodak specialist about this issue and he recommends changing your batteries to NiMh rechargeable batteries. These are the batteries that the camera is designed to use and using other types - like alkalines, can often cause the lens error to occur. If that doesn't work, then the camera indeed does need repair.
Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your Digital Camera - and you can recharge them up to 1000 times in our rapid charger.
Oxy-Alkaline Digital Camera Battery (AA Size).
CRV3 Lithium Batteries: A non-rechargeable battery designed specifically for today's feature-rich cameras. This battery is the obvious choice for speed performance, and long life. It delivers faster flash recycle times and lasts up to 10% longer than our previous design!
Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger,
Changing rechargeable battries 45-40
Metz 45-40 consist of 6 nos of NiCd - AA size batteries connected in series. These battery packs can be rechanged by resoldering new set of AA size rechargable Nicd battries. Care should be taken not to short circuit the cells when disassembling and assembling the cells. Keep a note (sketch) of the connections of the cells, specially the longer connecting metal strip and the polarities of cells. re-solder the new set of AA size NiCd Batteries. If the old wires were corroded, use new wires' If the connecting terminals also corroded' clean it. If it is severely corroded, get it plated prior to fixing for better performance.. There is an charging indicating lamp which also control the charging current of the batteries. check its connections and solder it if required. I wish you got the answer for your problem.
H.D. Shirantha.
1helpful
3answers
Cant find battery repacement
ebay.com or amazon.com or newegg.com should have it.
Batteries wont work on my Nikon L11
Hello
i have used Digipower AA rechargable and Everready AA rechargable batteries without a problem lasting a long time in this model.
you may have a problem with the battery charger itself.
batteries i am using are rated at 2400-2500 ma
in the menu button, select shooting menu - set up - scroll all the way down to battery type, select the battery type you are using and press ok in the center of the button.
you can use the coolpix nimh selection for other rechargable brands.
Top Reebok Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
