Washing Machines Logo
V
Venkat ramesh Posted on Oct 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer it will not change from wash to spin - Washing Machines
jhnolson
Level 3:
  • Washing Mach... Master 822 Answers
  • Posted on Oct 03, 2016
jhnolson
Level 3:
Answers
822
Questions
Helped
292559
Points
5434
If this is a top loading washer it is likely the lid switch.
If the tab has broken on the lid the switch will not actuate. The switch can be replaced by an experienced repairman. The power must be removed before attempting any repairs.
The washer will not drain or go into the spin cycle with the lid raised or defective switch.
Check that the tab is not broken!
washer it will not change from wash to spin - 26299541-mxigc5f5g2p33ovqwxs24jhd-3-2.jpeg
26299541-mxwasher it will not change from wash to spin - 26299541-mxigc5f5g2p33ovqwxs24jhd-3-14.jpgi
Testimonial: "Thank you"
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
Washer stays in wash cycle will not spin out i changed control board no help
Isyour washing machine displaying an error code? If so, try using the owner's manual to decipher the code and you may beable to easily diagnose the problem. The problem could be as simple as the doorbeing slightly ajar, the machine is in pause mode, or the spin selector isstuck. Checkthe handy chart in the article Washingmachine won't advance to washer spin cycle for more possible reasons why your washingmachine won't advance to washer spin cycle-and some tricks for getting itworking again.
My Kenmore washer will not spin or empty. Everything else works. Do I have to change the timer?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
2answers
Wont drain water
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
1helpful
Washer will not spin
There is a safety switch on the lid ... when it went out of balance perhaps the adjustment changed or it got damaged (loose wire etc.) BE SURE TO PULL THE PLUG BEFORE ATTEMPTING ANY REPAIRS
Washer doesn't spin
Hello skull1829 ,
Was the Clutch/One-way roller bearing changed out for dc/UC errors in your FAV6800AW/FAV9800AW?
If you start a Spin Only Cycle with an empty wash basket will the wash basket spin up CCW and complete the cycle? Lift the washer top from the base a few inches to observe the wash basket CCW rotation in spin cycle. If the clutch spring is broken or end pins of spring aren't seated the tumblers will rotate and the wash basket will rotate slowly CCW.
IF the wash basket won't spin up can you pull the front cover off and insure the motor will rotate the clutch pulley CCW in a Spin Only Cycle? Let’s try these few basic tests and get some feedback for troubleshooting.
Rich
Washer washes fine and the water drains but will only spin if you mess with the clothes making them perfectly balanced or you hand start the spin. Roper
sounds like the spin basket drive.. does it agitate ok? if yes get a new washer or change or get a repair man to change the spin basket drive.
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
2helpful
2answers
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Top Washing Machines Experts
john h
