There is a float inside, the float should be nearly to the shut off position when the dishwasher is full. If it isn't add water until it's about 2 inches deep, or within 1/2 inch of overlowing the front of the dishwasher. Run a cycle and see if your dishes are cleaner. If so, then the likely problem is with the water pump. Take this off, clean all screens and soak in Lime-Away or something similar and reinstall. In all probabilty if the dishwasher doesn't fill, there is dirt in the pump screen or buildup in the pump itself. If this does not fix the water level, then a new pump may be necessary (around $20-$40 on eBay).
To
clean the dishes the water temperature is essential.It the water is not
hot then the dishes will not be cleaned properly.So check the water
temperature.
Also check the filter in your dishwasher.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
