SOURCE: fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
SOURCE: looking for instruction manual for Stanley Fat Max
The manual is available at the Stanley support site: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-5162309471456573043/view_document!PAGETYPE?sq=FatMax%2b77-189&sc=2&sf=101113&sg=1&st=405165&documentid=342296&action=view . The direct link is: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-5162309471456573043/!DOWNLOAD?entryid=342296&attachid=29375 (but I'm not sure this will work).
If you have problems with those links, start at: http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-6221370935515628266/front_page!PAGETYPE?category=2 . Enter 77-189 in the search box and then click on the link.
I hope this helps.
SOURCE: How do you change the blade in a Stanley fat max knife 789
Don't touch the blade by hand use a pair of pliers. There should be a screw in the center of the handle, just remove it and you will see how to remove the blade.https://youtu.be/pFnbiw88Z8c
