Question about Sewing Machines
What is turning
Turning on childs baby jumper collar
Posted by Catherine Neil on
R.A. Ellis
  • Sewing Machines Master
  • 12,731 Answers
Could be a couple of things.
If you are sewing a new collar, turning is done after you've sewn three edges together and then you turn the item so the right sides are out and the raw seams are enclosed inside the collar. Then the collar is attached to the garment using the fourth (unsewn) edge.
https://www.craftsy.com/blog/2013/12/sewing-perfect-collar-points
How to Sew Collar Points Melly Sews
Or turning on an old, worn garment is when the collar or cuff is unstitched from the shirt and then flipping it over so the worn part is on the underside and the fresh, clean part is facing up (as against the neck edge or, in the case of a cuff, against the arm). This is an idea from the depression era when people wanted to get more use out of an item that was showing wear.
Turn shirt collar
Posted on Oct 02, 2016
I don’t understand how to sew collar on in B 6107. I’m confused by whether I sew to facings and how I turn collar inside out
Hello, Joyce -
I hope I am correct in understanding you are referring to Butterick pattern 6107. If so, I don't own that particular pattern and accompanying instructions. Am I also safe to assume you do not have the sheet of written instructions with images to accompany the garment pattern? In case you have the pattern pieces but not the sheet of instructions, you may wish to contact the McCall Pattern Co. (Butterick is one of their brands) directly via email here: https://butterick.mccall.com/how-reach-us . Note: They may charge for replacement instructions.
In the meantime, assuming I am correct about your sewing Butterick pattern 6107, I see the coat has 2 collar styles - 1 a shawl collar and 1 a stand up collar.
If you are sewing the shawl collar version, perhaps this online tutorial (with pictures) on sewing a shawl collar will be instructive:
http://sewastraightline.com/2010/10/21/shawl-collar.html
If you are sewing the stand up collar version, this online tutorial (with pictures) may provide the right instruction: http://everythingsewing.blogspot.com/2013/03/adding-stand-up-collar.html
If neither of those resources seem helpful, then you may find an experienced sewer in your neighborhood who will offer to help show you what to do. How to go about that:
- If you are not already a member of the neighborhood web site Nextdoor.com, I recommend you join it (free.) You will be able to identify and limit your "neighborhood" when you register.
- Once you are a Nextdoor.com member, post a question asking if someone in your neighborhood could instruct you in how to sew the kind of collar you wish to sew. Note: I recommend using the private message feature to share addresses and phone numbers.
- There will probably be a kind neighbor or two who will be willing to come to your home and demonstrate to you one-on-one on how to sew the collar and turn it out.
If you would rather not follow the Nextdoor.com route, then, my last option is for you to contact the local public school system and ask for then name and contact information for the person / people who teach sewing (probably in middle school / junior high school) in the school system. Then contact a sewing teacher and ask her/him if you can arrange a lesson with her/him on how to sew your collar. I recommend offering to pay for the teacher's time.
Best wishes.
Nov 30, 2017 | Sewing Machines
Baby Lock Esante needle wont go to the center position, only the left of center. sews fine but wont sew in the center
Go into utilities and turn width control off. Then select a stitch that has the needle centered.
Mar 27, 2017 | Baby Lock Sewing Machines
I'm having problems attaching collar to top A of 5556 butterick Help
Difficult to advise since we don't know what type of collar it is. Perhaps, take the pattern and your garment to the local fabric store and ask one of the wonderful ladies there how to proceed. You can also check out some sewing books at the library.
Or contact Butterick directly:
https://butterick.mccall.com/b5556?page_id=371
Apr 18, 2016 | Sewing Machines
I have a baby lock pro line BL4-736 but the fabric does not walk. Could anyone help ?
  1. Tighten the Large Silver Presser Screw on the top of the machine about 2 full rotation turns to the right.
  2. If it already tightened down, loosen (turn to left), 2 full turns. Use a nickel to fit into the slot on the top of the presser Screw.
  3. Dull blades can cause fabric not to feed, just bunch up in front of the blades.
Sep 01, 2015 | Baby Lock Sewing Machines
Baby lock elizabeth how do you turn the speed controller mode to off
The slide switch with arrows towards the top is what will do this.
Apr 28, 2015 | Baby Lock Sewing Machines
Why foot will not depress enough
Presser foot pressure is adjustable. Open the head cover and look for the presser foot shaft behind the light. On most models there is a spring around the presser foot shaft that pushes on a collar. The collar is adjustable (higher up pushes down more) and held on with a socket head screw (use a hex wrench).
Jan 11, 2015 | Sewing Machines
Esante machine not recognized on computer
Please contact Baby Lock for help.
Oct 05, 2012 | Baby Lock Esante
Hello I have a singer model 4552 I cant make the pressure foot stay up...the lever doesnt raise the foot high enough what doi do?
I have a used unit with the same problem. If you remove the plastic housing piece on the far left you can see how the foot lifter works. Raising the lever raises a collar around the main shaft. There is a screw in that collar which connects the collar with the shaft. If that screw is loose the collar will not raise the shaft. Caution: Tighten the screw very carefully, only enough so that the shaft lifts. I just overtightened and the collar has a crack now.
Sep 30, 2009 | Singer Sewing Machines
Reverse stitch
Gummed up with lint and old oil is the most likely.
If you place the unplugged machine on it's back & remove the base and press the reverse lever to see where the connecting rod is attached, you will see something like a collar around the shaft.......you may be able to move it bu hand and it may feel stiff.......use penetrating lubricant (like WD-40) and target spray to the shaft and aim to get between the shaft and collar by manually moving the collar back and forth......it may take several applications to work, and sometimes longer...just wiggle it for 30 sec a few times a day...most recent old singer was 17 days and may applications over that time !!
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Apr 13, 2008 | Husqvarna Viking 1
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
