Question about KitchenAid Ovens
SOURCE: OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at [email protected] Good luck
Posted on Dec 24, 2007
SOURCE: changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
Posted on Nov 06, 2008
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Posted on Jul 17, 2009
SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Posted on Aug 27, 2009
SOURCE: After using the self cleaning
If you slide your oven out and take off the center panel on the back of the oven you will see the thermal fuse. If it's like mine, it will be located (looking from the back of the oven) upper right hand side. It's an oblong loooking part with two terminals with wires attached to it and two screws holding it on. Once you take it off, you will notice that it is flat on the back side and you should be able to see part # 9759242. Only reason I know this is that I have just removed mine and am going to see if I can find one locally. Same thing happened to mine after putting it in the cleaning cycle to clean up after the holidays.
Hope this helps!
Robert
Posted on Dec 27, 2010
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
Sep 16, 2010 | KitchenAid KEBC107 Electric Single Oven
Jan 30, 2010 | KitchenAid KEBC107 Electric Single Oven
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
Oct 06, 2009 | KitchenAid Architect Series KEBC107KSS...
Mar 10, 2009 | DCS Large Appliances Built-In Ovens...
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
Apr 22, 2017 | KitchenAid Ovens
65 people viewed this question
