Question about Measuring Tools & Sensors
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
I have installed new batteries on both inside and outside sensors , the outside sensor is hanging from a branch on a tree approx 4 feet from the ground the inside is mounted on a wall about 4 feet from the floor the two are located about 100 feet apart. I tried just ac power and batt power on inside unit. I have reset the inside and removed batteries from both inside and outside units. I have done everything the trouble shoot has recommended and still the inside reads 26c. Whay do you reccomend.
Posted by Dennis Driscoll on
richie46
    Top Expert:
  • 12,962 Answers
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Posted on Oct 02, 2016
Testimonial: "I know how to change from cel. to farn. it's the number that stays the same."
  • richie46 Oct 03, 2016
    If the "C" is always appearing then it is not changing to Fahrenheit. Those weather stations are are a PIA to set correctly. If you still cannot do so, then something is wrong with the unit - the receiving unit. On mine the outdoor temp never changes! )(&^%^&%^&**
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
Oct 02, 2018 | Acu-Rite Acurite Wireless Weather...
New owner of AcuRite Model 75075. Outdoor temp (just now installed) is reading 7 degrees higher than actual tempperature. How lond does it take for the indoor & outdoor unit to get in Synch?
Typically the Sensors Sync-Up within 10 to 20 Minutes. However, placement of the Outdoor Sensor is also important. The National Weather Service (NWS) and NOAA measure the Temperature in the Shade, and NOT in the Sun. So be sure that your "Exterior Sensor" is placed in the Shade, under an overhang for example. However, be careful not to place the sensor under an overhang, where there may be a soffit-vent or gable-vent, that is used to vent out warm air from the attic. Even a three (3) season, unheated porch can be warmer than the actual external temperature, due to passive/solar heat captured thru the windows (East/South/West).
Jun 08, 2017 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed?
Try repeating the initial set up procedure. Remove all batteries from outdoor and indoor units. Install known-good batteries in the outdoor unit. Allow time for the outdoor unit to begin transmitting data. Install known-good batteries in the indoor unit. You should see the outdoor temperature displayed.
Feb 09, 2016 | AcuRite Acu-Rite 00621 Wireless Weather...
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
Acurite Manuals
Remove new batteries from the indoor station. Carefully remove batteries from the remote sensor, then reinstall. Reinstall new batteries in the indoor station. DO NOT TOUCH ANYTHING FOR AT LEAST 10 MINUTES. You should see the outdoor temperature displayed and can then proceed with other settings.
Nov 03, 2013 | Measuring Tools & Sensors
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Measuring Tools & Sensors Logo
443 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
