Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
I understand that you are trying to reset the controls on your Frigidaire freezer, model# FFU14F5HWN, after having a power failure. To reset the control after a power outage, all you will need to do is press the "Alarm Reset" button. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Hope this is helpful.
some of these had resets others reset after you unplug it for about 20 minutes and replug it in. some older models you had to hold in the power button for 5 to 10 seconds.
Hello - I understand the unit has previously experienced a power outage, however have you try unplugging the unit or flipping the household breaker off? Wait approximately ten minutes; is there power to the unit? I suggest touching each button individually on keypad, do any lights turn on or does the display change? If any proves to be ineffective, I would recommend contacting a professional to move forward accurately because it can possibly have a defective keypad.
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
Sometimes you have to unplug the monitor from the power supply and wait at least 30 seconds before plugging back in, and make sure you don't need to press the reset button on the power strip.
the rinnai is like a monitor. just unplug it, wait five min and plug it back in. then radjust your temp set point and it should pick back up. when there is a power outage the led-s flash 88:88
