Question about Philips Televison & Video
Hola primeramente hay que ver si su dvd trae hdmi por que casi ninguno lo trae , de traerlo solamente tiene q buscar el cable hdmi conectarlo y seleccionar en su dvd la salida hdmi y en su tv la entrada hdmi en el men? del tv,..,. saludos.
Posted on Dec 31, 2016
SOURCE: "Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
Posted on May 18, 2009
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
SOURCE: I just bought my Philips 32" lcd tv and tried to hook up the ps3
you have to first plug in the s-video before you use hdmi so you can set it to HDMI on your ps3 when you go to your setting. Then it should work. If you already did that and it still doesnt work its probably the HDMI cord
Posted on Jul 29, 2009
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
Jun 09, 2013 | ViewSonic N3240wb-e 32 in. LCD TV
Dec 01, 2012 | Sceptre X240BV-FHD LCD TV
Jun 09, 2012 | Philips 32PFL5403D/27 32 in. LCD TV
Jan 05, 2010 | Philips DVP3982 DVD Player
Jan 02, 2010 | Philips 52 In. LCD HDTV
Nov 24, 2009 | Televison & Video
Aug 10, 2009 | Philips 32PFL3504D 32 in. LCD TV
Feb 08, 2009 | Philips DVP5990 DVD Player
Feb 09, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
Feb 09, 2008 | Philips 51PW9303 51" Rear Projection...
Jan 15, 2021 | Philips Televison & Video
