Washing Machines Logo
Question about Maytag Washing Machines
My Maytag has F51 error code
Posted by Dru Sabune on
Marvin
    Top Expert:
  • Maytag Master
  • 85,242 Answers
F51 would indicate that the control board is not seeing the proper resistance on the motor circuit . You should check and make sure there are not any articles, stuck between the tubs, or under the agitator. Make sure you're not overloading the machine and that you have proper voltage to the unit. It can also indicate that your rotor position sensor is either not registering or it is just bad. Remove and reinstall the connector at the RPS to clean off any corrosion built up on the connector. After that go ahead and try to run a cycle. If that does not work and you continue to get the same error, replace the RPS sensor.
Posted on Oct 01, 2016
5 Related Answers
Mukesh Kumar
  • 3230 Answers
SOURCE: error code F51
Well, the code means a rotor position sensor error. The first thing you want to do is see if the basket turns freely by hand. I had one the other day where a dish towel was caught between the basket and tub giving the error. You will have to open the top by using a putty knife and pushing in on the clips on each side. They are strong clips so you have to use some force. The whole top will lift up. Next you will have to remove the tub ring. It just snaps off. If you don't find anything between them, then I would suspect the rotor sensor itself. At the factory they sprayed a protective coating on them and sometimes this causes the problem. You would have to tip the washer back. The motor cover comes off witha allen head, just pulls down. Now there is 4 screws that hold the motor in place. Once you drop them, the plastic cover protector will come down along with the motor so observe carefully where it mounts back up. The motor connector will be the 3 pronged harness on the right side of the motor. The rotor position sensor will be on the left. Snap the position sensor in and out about 8 or 9 times to get the coating off. If this doesn't work, and you keep getting the error, you will have to order the position sensor.
Good Luck!!
Thanks
Posted on Dec 27, 2009
Anonymous
  • 311 Answers
SOURCE: iam haveing a error code of f51 on my maytag
There are two possible causes of this code an unbalanced load can cause this error, The unit usually tries a few times to redistribute the load before it will display this error. Try another load if the error occurs then you have bigger problems. The other cause could be a bad rotary position sensor on the motor in which case you would probably want to call a tech.
Hope this helps _MJ_
Posted on Jan 31, 2010
SOURCE: f51 error code on Maytag Bravo
To correct this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connection. Confirm that the connector is fully seated onto the RPS control upon final connection and verify there are no damaged wires.Replace the electronic control. The upgraded control is less sensitive to intermittent RPS connections.
To learn more about your washing machine, or to order parts, click here.
Posted on Mar 07, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: maytag washer flashes f 51
You will need to replace the RPS sensor. There is a kit available that will update that washer to the current design. Here is the kit to order.
Posted on Nov 23, 2012
Anonymous
  • 5 Answers
SOURCE: f51 error code on wtw6700tw washer. Lost the tech
Was a far easier fix for me than all this RPS sensor hunting. For my machine's F51 error, there were socks lodged between the inner and outer tubs, causing too much friction on the motor. This led to the computer reading poor performance of the motor. Please consider trying this easy fix before calling out service personnel or replacing circuitry!!! I spent hours under the machine messing with the motor and circuitry until I looked up at the translucent tub and saw stray laundry stuck where it shouldn't be.
* Open the lid. Turn the bottom agitator by hand. Give it a good push. It should continue rolling on for several turns. If not, there is laundry stuck between the tubs causing friction.
1.) Pry open the metal case lid. Take two flat head screwdrivers and wedge them in the crack about 6 inches from the left corner, and use them as levers to pop the metal lid, then the right corner. Lift up the metal case lid and lean it against the wall.
2.) Take off the plastic ring that bridges the gap between the inner and outer tubs. There are many little catches all around the perimeter of the outer tub that hold on this plastic ring. Find those catches and put outward and upward pressure on those to release the catches.
3.) Look down in the gap between the inner and outer tubs for stray laundry. I used a retrieval tool, below, to grab the socks. There were especially several socks in the back right corner near the pump inlet. Run the drain and spin cycle and look again. There were more strays hiding that I nabbed the second time!
4.) Snap the inner cover on by lining up all those catches and seating them. Snap the big metal lid back on by aligning and giving a good downward thump. Run the machine and be the hero, and don't be too mean to your wife about tossing those socks down in the crevices. Half hour and $3 for the retrieval tool is far better than all that RPS nonsense.
Posted on May 20, 2013
2answers
What does an error code F51 on a whirlpool cabrio washer mean?
Cabrio F51 Fault (Stored Fault Code F51) The Cabrio's F51 fault code flashes on the washing machine's display when there is a motor rotor position sensor (RPS) failure.
Check for good contact at the control Board and at the RPS. Sometimes disconnecting and reconnecting the RPS plug connection several times will clean off corrosion that may be affecting the contacts.
Here is an earlier Fixya answer addressing the query:
Whirlpool cabrio error code f51 what does it mean
Sensor is item 20 below. Clean it.
F51 maytag bravo error code?
The F 51 code, would indicate, the control board is not seeing the proper resistance on the motor circuit .
Make sure you're not overloading the machine.and you have proper voltage to the unit.
Have you run the unit through a cycle empty ?
You may want to try that, before we have to get too involved in circuit and voltage tests.
Your technical data sheet should be on the inside of the front panel, you'll need to raise the top of the washer, using a putty knife to release the clips in the front seam, holding the top down .
Maytag washer Error Code F51 Appliance Repair Forum
Washer wont spin. F51 code
the f51 error indicates that your rotor position sensor) is not registering or it is just bad. try this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connections. after that go ahead and try to run a cycle. if you continue to receive the error then you need to replace the RPS sensor. Here is that part to order. Whirlpool W10178988 Sensor AppliancePartsPros com
What does it mean f 51
http://forum.appliancepartspros.com/washer-repair/131926-maytag-washer-error-code-f51.html
Maytag washer flashes f 51
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
I have a Maytag Bravos washing machine that has just recently become really noisy when it goes into high speed spin. I have lifted the cover and found no items or debris. When I spin the tub by hand it...
Hi.
F51 is motor position sensor error. From manual:
F51: Motor RPS Failure
F then 51 flashes when there is a motor rotor position sensor (RPS) failure or lower harness problem.
The motor position sensor failure may be the result of a problem between basket and motor.The parts below the basket must be inspected. There is need to remove the basket to check parts in there. I can give you the procedure to remove the basket if you want.
2helpful
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Washing machine display F51 on Maytag Bravo. How do I fix it?
F51 error code
The reason could well be due to an intermittent connection at the Rotor Position Sensor, (RPS).
Iam haveing a error code of f51 on my maytag washer was woundering what it meant
Top Maytag Washing Machines Experts
Robert
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
