SOURCE: canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
SOURCE: Error E007 canon IR 2016
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
To clear the error, execute the following in service mode: -
COPIER>FUNCTION>CLEAR>ERR.
to open service mode press star press 2 and 8 key same time then press star again.
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
I have a machine it write DOWNLOAD STANDBY.Hw may i do it.
