Computers & Internet Logo
Crack Password on linkbook v101 - Computers & Internet
1 Related Answer
lolthepcman
  • 179 Answers
  • Posted on Nov 09, 2017
SOURCE: I have forgotten my Linkbook v101 password and username and cannot do anything on my laptop I cannot even access factory settings
maybe if you read this you might be wiser. http://www.linux-netbook.com/linkbook/
Can anyone help to remove the forgotten password on my linkbook v101 please I'm desperate
Have a look at manual it will help.
https://www.donkeyfun.net/LP_TA/index.cfm?T=439380
1helpful
2answers
How to oen your laptop again if you forgot your password
You can crack dell password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
7helpful
Vw passat 2000 1.8t front wheel drive
please rate me solved...thanks
DTC P0411/16795: SECONDARY AIR SYSTEM - INCORRECT FLOW DETECTED
Test Requirements
Ensure all fuses are okay, battery voltage is at least 11.5 volts, all electrical accessories are off, A/C is off.
Ensure engine is mechanically sound.
Test Procedure
NOTE
Secondary air system is activated by ECM and blows air into exhaust pipe
upstream of catalytic converter for 100 seconds during a cold start, 41-91°F (5-
33°C). Engine must be cold to perform following test procedure.
1. Ensure fuse and secondary fuse (secondary fuse is 40 amp and is located in fuse holder on top of battery)
are okay. Check hoses and components of Secondary Air Injection System, for damage, loose fit and
improper installation, check vacuum hoses for Secondary Air Injection System. Repair as necessary.
Erase DTC memory. Verify repair. If DTC does not reset, test is complete. Perform ECM relearn
procedure. See TEST DRIVE RELEARN PROCEDURE .
2. Remove engine cover. Disconnect pressure hose from Secondary Air Pump Motor (V101), by pressing
buttons on hose connector. See Fig. 33 . Using scan tool, check Secondary Air Pump Motor (V101) in
scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See OUTPUT
DIAGNOSTIC TEST MODE .
3. Secondary Air Pump Motor (V101) should run in intervals and air should exit pump at hose connection.
If Secondary Air Pump Motor (V101) is okay, go to step 7 . If motor runs and no air exits secondary air
pump motor, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test
is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE . If
secondary air pump motor does not run, go to next step.
4. Disconnect Secondary Air Pump Motor (V101) harness connector, install LED test light at secondary air
pump harness connector terminals. Turn ignition on. Using scan tool, activate Secondary Air Pump Motor
(V101) in scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See
OUTPUT DIAGNOSTIC TEST MODE . LED test light at Secondary Air Pump Motor (V101) harness
connector should flash. If LED test light at Secondary Air Pump Motor (V101) harness connector does
not flash, go to next step. If LED test light at Secondary Air Pump Motor (V101) harness connector
flashes, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test is
5. Using DVOM check resistance of Secondary Air Pump Motor (V101) wiring. See appropriate WIRING
DIAGRAM under ENGINE PERFORMANCE in SYSTEM WIRING DIAGRAMS. Resistance should
be a maximum of 1.5 ohms for each reading. Check wiring for short circuit to one another in Secondary
Air Pump Motor (N101) harness connector. Repair as necessary. Erase DTC memory. Verify repair. Test
Secondary Air Pump Motor (N101) wiring is okay, go to next step.
6. Check Secondary Air Pump Relay (J299) and Secondary Air Pump Relay (J299) wiring. See DTC
P0418/16802: SECONDARY AIR PUMP RELAY (J299), MALFUNCTION . Repair or replace as
necessary. Erase DTC memory. Verify repair. Test is complete. Perform ECM relearn procedure. See
7. Disconnect vacuum hose from Secondary Air Injection Valve (N112) and disconnect pressure hose from
secondary air pump motor, press buttons on pressure hose connector to disconnect pressure hose. See Fig.
34 . Blow lightly into disconnected pressure hose, Combi-Valve should be closed. Connect hand vacuum
pump to disconnected vacuum hose and apply vacuum to Combi-Valve, Combi-Valve should open. If
Combi-Valve opens when vacuum is applied, Combi-Valve is okay. Go to next step. If Combi-Valve
does not open when vacuum is applied, replace faulty Combi-Valve. Erase DTC memory. Verify repair.
Test is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE .
8. Check Secondary Air Injection Valve (N112). See DTC P0412/16796: SECONDARY AIR
INJECTION VALVE (N112), ELECTRICAL CIRCUIT MALFUNCTION . Repair as necessary.
NOTE: Do not use compressed air to check Combi-Valve.
2000 Volkswagen Passat GLS
2000 ENGINE PERFORMANCE Self-Diagnostics - 1.8L Turbo
Grand Canyon Tech
Grand Canyon Tech
