Question about Soyo Computers & Internet
Soyo Topaz S LCD monitor (MT-GW-DYLM24D6) has no audio input but makes harsh sound for a short period during Windows Vista power up. What is wrong and how to fix?
Originally it had no sound at all.
2 Related Answers
yutianyunren
wisiny.com
  • 848 Answers
SOURCE: Fuse Blowing in Power Supply SOYO MT-GW-DYLM24D6 24
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
BSFP2415004A5 Soyo CGCPOM24EI4 Power Supply for MT GW DYLM24D6
Posted on Nov 17, 2014
yutianyunren
wisiny.com
  • 848 Answers
SOURCE: Monitor says its out of range Its a 24" wide lcd
Will not power up
Always, always the problem with monitors is the "power supply board", and that is almost always a blown sixty-seven cent (or so) capacitor.
Here is a seller on Ebay that will send you EVERY capacitor it might be, and will make a few cents on the deal: http://www.ebay.com/itm/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-/330499791194
Open the monitor case up (Google for instructions) and see if you can observe (or smell) the bad capacitor. You will be able to tell what component I am talking about after looking at that ad on Ebay for the capacitor kit. If it is patently obvious to you which capacitor it is (as sometimes it can be), go to the Radio Shack in the local mall, and buy a cheap soldering iron, a bit of solder, and the specific capacitor you need.
(you will have to hurry however: Radio Shack went bankrupt, and all the stores will be closed by the end of this month)
However you do this, the Fixya will be under twenty bucks, and the monitor will be better than new! Read the instructions in that Ebay advertisement, too - you will understand how easy this fix is when you do.
Mar 07, 2015 | Soyo DYLM24D6 LCD Monitor
Won't power up
Bad power supply board capacitor, most likely.
99.99% probability.
(the other .01% is it is not plugged in)
Sep 03, 2013 | Soyo DYLM24D6 LCD Monitor
I HAVE REPLACE THE CAPS ON THE POWER SUPPLY BOARD OF A SOYO TOPAZ DYLM24D6 BUT I MADE A MISTAKE AND PLACE THE 2.2 50V CAP IN THE WRONG POSITION ON THE BOARD, COULD YOU PLEASE TELL ME THE BOARD NUMBER...
I canot find the free service manual for this model, but if you can post the pictures, then it may help me to tell you since the foot print of the 2.2uF will be so much smaller than the oher large value caps on the board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 22, 2011 | Soyo DYLM24D6 LCD Monitor
I have a soyo dylm2284. On power up it displays screen but quickly turns itself off untill I power back up....Any suggestions to fix. It is out of warrenty
It may have backlight power supply problem or inverter circuits problems.
Check for caps with domed tops first.
http://lcdalternatives.auctivacommerce.com/Repair-Kit-Soyo-Topaz-DYLM24D6-LCD-Monitor-P1660441.aspx
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
Jan 21, 2011 | Soyo DYLM24D6 LCD Monitor
My Soyo 19" TFT monitor Model:MT-NI-DYLM1998 comes on at power up but goes black after a few seconds. But on repeating turning power off then on again, the monitor comes on and then goes black again after...
Thank you for answering those questions. That usually indicates it has a bad power inverter. From what i can tell, that monitor is a few years old. You can attempt to find an inverter online to replace it yourself (usually about $50 if you can find one) since its no longer covered under warranty, or put that money into getting a new monitor.
Sep 06, 2010 | Soyo DYLM24D6 LCD Monitor
My Soyo DYLM24D6 monitor screen goes black on reboot, can hear Windows XP Pro loading music but cannot even see the start-up screen from motherboard BIOS. I'm trying to find SOYO website but keep getting...
I would not be surprised if it does have bad caps in the power supply section.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Aug 06, 2010 | Soyo DYLM24D6 LCD Monitor
My monitor starts to flicker and sometimes it's so bad it goes black the only way to make it stop is to adjust it up and down or turn it off and back on again
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further, it will also help out other people with the same problem.
Apr 05, 2010 | Soyo DYLM24D6 LCD Monitor
I need a new driver for my soyo monitor
Your soyo monitor doesn't require a driver. Make sure you download and install the latest driver for your video card and during the install of that, your monitor should have its drivers installed as well. At that point you'll be able to use your monitor properly. There isn't any drivers available on the net that I could find. Only other option is if your monitor came with a cd, that might have drivers on it.
Jan 14, 2010 | Soyo DYLM24D6 LCD Monitor
If you can solder connectors you can build your own power supply for SOYO. Try the following link or google "gbyer external power supply".
http://slickdeals.net/forums/showthread.php?t=1655449&page=5
Replacement power supplies were avilable recently but it seems they are all depleted.
Nov 06, 2009 | Computers & Internet
Computers & Internet Logo
128 people viewed this question
Top Soyo Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
