My Mintek tv says hdmi unsupported when i plug the hdmi into my tv and 4th generation apple tv but it works fine when i plug it into my cable box. It worked a couple of days ago but now it doesnt
SOURCE: HDMI Cable - No Sound L42WD22 RCA Flat Panel TV
No sound and a digital picture. i will assume you have no signal on analog rf cable. Thomson(RCA) have been having problem with these sets. The trouble stems from the digital cuircit board. We see alot of these. You used to get the digital board.. they are not availble.. so rca found the component on these that fail.. A VERY SMALL surface mounted fuse. With a lighted magnifer and some fine tip twezzers. we replace these fuses on these boards. Do you have any soldering experence..
SOURCE: akai lct42z6tm
I can confirm that replacing these 4 capacitors worked perfectly. I
work in construction so i am not a technician or anything. I did not
even have a solder iron. I have photos of the board if anyone would
like to see them. Took me about a hour to replace the 4. I had to use
(2)35volt & (2)50volt cause radio shack only had 2 of each and it
works like a charm. This TV has been in storage for 6 months until i
found this article on the problem. Cant say thanks enough!!!!!!!!!!
SOURCE: Sony HDTV flat - no picture with HDMI cable and Verizon FIOS box
Probably a handshake problem with the cable box. It is common for cable boxes to have HDMI handshake problems. Hook the box up using the component cables and you should be fine
SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
