Question about Neff Cooktops
Suitable replacement for a Neff T184 induction hob
Old T184 hob needs replacing. Want something that can be easily installed as a replacement
Posted by Norman Embleton on
My Neff induction hob shows an error code of er 22?
That means circuit board error. You will need a replacement or tech.
Oct 11, 2018 | Neff Cooktops
F4 code keeps flashing the hob is not hot as I have not used for a few days
Go to this website and they have a online helper to assist you with your issue. This is free. http://www.neff.com.au/service/support/induction-cooktops/not-working
Dec 04, 2017 | Cooktops
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Jun 18, 2009 | Cooktops
Safety lock on Neff hob
I have a Neff T4344N0/08. I cannot stop all four hobs flashing - ie: I press the 'on' button all four flash, I then choose which one I want to use plus the number but they all keep flashing instead of stopping after the usual three or four. Please help - have I pressed something I shouldn't, perhaps a child lock?
Sep 27, 2008 | Neff 23 in. T4343 Electric Cooktop
Cooktops Logo
175 people viewed this question
Top Neff Cooktops Experts
Lee Hodgson
Lee Hodgson
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
