SOURCE: hp deskjet 3550 problem
Green light blinking is indicated that u r one of the cartridge (or both cartridges ) are faulty .please check u r printer with tested Ok cartridges ...it should be resolved
if this information is useful for u please Rate me .........
u r Rating is Important for me.
SOURCE: HP DESKJET 1280
I have the same problem. Yellow light now constant and will not print at all.
SOURCE: blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
SOURCE: hp deskjet power lifght blinking
take it apart and see if you see anything broken if nothing take it into the store because it is more than likely a factory error
SOURCE: HP Deskjet D2360, blinking green light,
Click Here and follow the instructions to resolve this issue.
