Question about Xerox Office Equipment & Supplies
Scanner has failed to initialize error in xerox 5755 while copying the multipages with platencover
Posted by muhammed imran on
Zeeshan Hashmi
    New Friend:
Give me answer please
Posted on May 18, 2019
5 Related Answers
Rick Kasper
  • 2072 Answers
SOURCE: xerox copier
Sounds like the IIT ( scanner board) or the lens assembly has failed.
Most likely the lens assembly.
Posted on Jul 01, 2008
Adorjani Laszlo
  • 1316 Answers
SOURCE: scanner will not initialize properly, can make
If the scanner is not positioned correctly ,indiferent to make a copy to use the ADF or make to the original glass the copy problems is identical.Clean the scanner glass,original glass and the white level band,the erase lamp and check the OPC drum.If the problem persist need to perform the FD and CD adjust for the paper tray.Make someone copies use the A4R tray,and A3,and see the different.
Please answer to help you.You need the position correctly the problem source.
Posted on Aug 22, 2009
Anonymous
  • 55 Answers
SOURCE: When runnung the X2470 scanner form Windows Photo
Did you allign the scanner? Print a test paper and then put the load the paper into scanner. Choose to allign.
Posted on Nov 06, 2009
Anonymous
  • 3741 Answers
SOURCE: My scanner fails to scan documents.
there are many users facing this same error message.
there are options to solve the issue.the upper part of the printer is scanner.you have to remove that upper portion by removing the screws and internal locks on its inner layer.then check out if any dust is got collected on the scanner lens.the lens is a thin glass layer in the scanner that reads the document which you place on the glass.if the dust gets collected on the lens it will show this error messages.but if after cleaning it shows same message that means the internal board is got faulty.there is a mini circuit board beside the scanner glass.internally.so the upper scanner assembly needs replacement.in the scanner assembly set you get the new circuit board.scanner assembly means not the upper scanner glass it only includes the inner assembly and the circuit board of scanner assembly.the cost of new assembly is near to $40.you can get this assembly at any local printer repair shop.they have it in spare or they can easily get it from nearest service center of the hp company.
thanks.
Posted on Nov 20, 2009
SOURCE: Xerox M15: Blank copies
There is a problem with the Laser Unit
need to replace the LASER nit or need to open and clean the unit will solve the issue
Posted on Jan 22, 2010
Xerox machine 5755 scanner has failed no lamp on
This seems to be a common problem on this Xerox Series of multi functions. Your going need to locate a service tech to replace the scanner assembly to get this machine going again.
If you need more help, consider downloading the 6ya app for your Iphone or Android from the Apple Store or Google
Play Store and giving us a call via the easy to use app. Any of us would be happy to give you a hand further.
Thanks!
Charles
Aug 03, 2018 | Xerox Office Equipment & Supplies
Xerox 5755 xerographic module cleaning failure...... how to solve this error
"Xerox 5755 xerographic module cleaning failure...... how to solve this error"
Jan 25, 2018 | Xerox Office Equipment & Supplies
I have a problem of fuser module (r3) temperature error in xerox workcentre 5755
Can you feel any physical heat from the fuser. Sounds like either the thermistor that controls temperature or the lamp failed.
Sep 15, 2016 | Xerox Office Equipment & Supplies
How can fix error code 14-563 on xerox work centre 5755
THE CARRIAGE FOR THE SCANNER IS FOULED UP WITH SOMETHING
Aug 25, 2016 | Xerox Office Equipment & Supplies
Format a xerox 250 hard drive
Sometimes you can format it on a windows or linux based machine to the correct format for the printer. You will have to find out which format it expects.
If it says initializing for an extended period of time, it is most likely formatting it and you just have to wait.
Make SURE you absolutely destroy the old hard drive completely. It contains copies of everything you have ever copied..
Feb 19, 2013 | Xerox Computers & Internet
I have a WorkCentre XK35c/25c that I now use just as a copier.(Not hooked up to computer) When turned on it has power but when you hit start it sounds like it is going to copy as the light bar goes across...
The scanner for the flatbed has failed to properly move. The rails may be dirty, or the motor may be binding. Additionally there is a home sensor switch that must be activated when the scanner is initialized. Finally, when the copy button is pressed, does the lamp on the scanner come on within a few seconds?
If not, the scanner lamp may have failed.
Zenbob
Jul 28, 2008 | Xerox Office Equipment & Supplies
1,447 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
