Generic RCA LED55G55R120Q 55" 1080p 120Hz LED HDTV Logo
F
Frankie Moyer Posted on Sep 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A led55g55r102q RCA tv that wont turn on and the power light on the front does not light up
Want to know if their are any power board issues. I wil e trying a new power cord. The unit production date, 11/2014
Level 3:
Top Expert:
  • Generic Master 76,851 Answers
  • Posted on Sep 29, 2016
Generic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004182
Points
237762
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
While watching a movie on my RCA tv. model #HD52w59, it just lost all power and wont turn back on and the green power light does not light up. there is powere at the putlet so i know its something with the...
check first loose or broken power cord. if ok, what you can do is look for the power supply board look for blown fuse sometimes due to voltage fluctuation the fuse get blow.
1helpful
Rca Tv wont power on HD61W66
Sounds like the capacitors on the deflection power board CP150, CP120 and CP114 they are famous for failing in all versions of the ITC222 chassis. You can get the repair kit by that same name from www.tvrepairworld.com the kit has the caps and the cd with repair instructions
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
2answers
Tv wont turn on just get a red blinking light on front tried to unplu but wont work still
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem
1helpful
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
I have a rca 52inch hd52w56 power light on front of set is solid,then flashes ten times,then solid again for a minute. repeats. tv will not turn off or on. ???? screen not on,no picture,no sound,nothing??
DM power board have some dead capacitors.Some capacitors bulge up,best indicatoin it dead,some u must used a multimeter to test.U know how to use a soldering iron and solder?Change all the DM power board capacitors,should get power back to ur tv.Try website Tv repair World.com maybe still selling this refurbish DM power board.
1helpful
2answers
MY RCA TVE WONT TURN ON
Open up the front and check for fluid under the CRT circuit boards. The one on the right (as you face your TV) is the blue one. For some reason, the diaphram for the glycerin in the blue optic is on the back side and leans down. It tends to leak and spill on to the circuit board below.
Tell tale sign is the pool of fluid when you access the front chassis. Pull off the speaker grill and shine a flashlight on the inside underneath the CRT circuit boards and look for the fluid. Glycerin doesn't dry. TV is powering off most likely to protect itself from the shorts.
Top Generic Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Generic Televison and Video Expert? Answer questions, earn points and help others
