Samsung HP-R5072 50 in. Plasma HDTV Logo
D
David Perry Posted on Sep 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv comes on for a few min and goes off does this for about and hr then it will stay on
Richard Warren
Level 3:
Genius:
  • Samsung Master 2,548 Answers
  • Posted on Sep 28, 2016
Richard Warren
Samsung Master
Level 3:
Genius:
Answers
2548
Questions
Helped
640674
Points
6606
Could be the screen about to fail ,heating up.
Sleep mode
Reinstall the Power management . Install the updated graphics drivers
1helpful
2answers
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
TV comes on stays on for a short time than goes black with loss of sound green flashing light untill TV comes back on. takes maybe 2 min.
Tv fades to black very low sound or or goes to blue & says lost siginal then goes toblank turn off set & waite a few min.& turn back on will only stay on for a few min. have to repeat.
This is not a "digital" problem that can be addressed in your setup or fixed at home. This sounds like a fading power supply. Often electronics fail slowly or partially.
You will need to consult a TV repairman.
I hope this helps!
1helpful
Wharfedale 42f1080p faulting?
Replaced any swolen capacitors on the power board.
TV turns off by itself
Thus the line connected to a surge protector or some kind of line protector. This can be consider.
Or if this is a crt type tv. This could be a fault on high voltage section. Horizontal output transistor or flyback. But check also for loose connection/solder crack. That clicking sound may be the relay in action.
hope i give some correct input.
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
3answers
Powers off by itself.
Power supply or sweep suppys have parts that are overheating and breaking down or cold solder connections. Call someone who knows this set like the local authorized magnavox/Phillips dealer/servicer. Good Luck
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
