John Deere Riding Mowers
Richard, Check the attached links,instruction and guides for wiring diagram. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Wiring diagram for john Deere model 125 Google Search
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
I have the same problem same year, same model. I changed the drive belt and it still won't go up steep hills that it used to easily climb. I don't see any way to adjust tension and it doesn't cover that in the operator's manual. What did you find out with yours?
