SOURCE: samsung ht ds1000 plays fine, but there is no sound.
you have not blown thye fuses the static sound suggests that that is not the problem
SOURCE: dvd does not load
some times its because of the CD (it cannot read the CD) all you have to do is try a different range of CD's to see what the prob is if it still doesnt read it may be coz of a scratched CD / Lens!!!!
SOURCE: samsung ht ds1000 audio problem
I had the same issue 6 months after I purchased the unit. Worked with tech support several times. Finally they sent new woofer and that fixed it.
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
SOURCE: Hello! Pls, send diagram connector to
The speaker connections are documented in the manual. Register and download the manual for free at
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
retrevo.com95 views
