Question about Panasonic KX-T7731 Corded Phone
How do I get my voice mail to tell me the date and time that the caller left a message on the
Posted by Mandy Miller on
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: How do I set the time and date on the phone and change voice mail
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM 99 on a display phone and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following: Press PROGRAM * * 1234(Default password is 1234. yours may have been changed) Press SP-PHONE 2 Times. To change the year enter the two digit year. If it is correct press FWD/DND to move the flashing indicator. MONTH is changed by pressing the AUTO ANSWER /MUTE key. DAY is entered as 1 or 2 digit day. DAY OF THE WEEK is entered by pressing the AUTO ANSWER/MUTE key. Press STORE to save your changes. Press SP-PHONE Enter 2 digit hour (Hour is flashing). Press FWD/DND button(Minute starts flashing). Enter 2-digit minute(Minute is flashing). Auto Dial/Store Button New time is stored. Lift handset and hang up to leave programming mode
Posted on Sep 16, 2007
Anonymous
  • 201 Answers
SOURCE: Recording messages
You are asking about changing you voice mail and phone system settings. Your phone can work on several different Panasonic phone systems and you could have different voice mail systems as well.
The phone KX-T7633 has only a user guide that covers the basic features of the phone itself. You need a programming and installation manual for your phone system AND your voice mail. They are not the same part and have different manuals.
So, your first step is to find out the model number of your phone system and voice mail system.
Posted on Oct 10, 2007
jlai
SOURCE: can not access the voice mail. can not leave voice mail.
Just need to power off and on the system.
Posted on Dec 03, 2008
Anonymous
SOURCE: can not get rid of New voicemail message
Press and hold the off button until the handset beeps
Posted on Jun 23, 2010
Anonymous
SOURCE: New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
Posted on Jul 15, 2010
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
My message light will not turn red so I am not aware that I have a message. If I push the "message" button, it is busy
You are missing a lot of information, but here goes. Your message light is unlikely broken in a new phone. Have someone ring your extension and press "4". Now look at your phone and press MESSAGE. The display tells you who left the message and you get 2 options on your soft keys to call or erase the message.
Now, here's the part you left out. What is leaving the message? It could be coming from CO based voice mail, a TVA system, or a SVM card. If it's a TVA voice mail system, it has to be programmed with your mailbox and extension (usually the same). A message left in the General Delivery Mailbox doesn't light anything unless it's programmed to do something, and a message left in your box usually works if it's properly set up to begin with. We try to set up our TDA's to eliminate GDM messages, so that means that Call Forward lights must be lit at every extension that needs voice mail and there's always a choice to direct callers to extension 101 or some other mailbox but the GDM. If it's CO based, you bought the wrong system, and an SVM card has a set of instructions to assign extensions to slots.
Most likely you'll find the missing information in the Programming Manual of the voice messaging system.
Carl
Jan 11, 2011 | Panasonic KXDT333 Phone
When someone calls my phone from another extension in the office how can I get the time stamp to show on my voice mail instead of the persons name?
The date and the callers name should display on the telephone. You cannot display the time stanp, however you can press 7 to listen to the message envelope, which includes the time stamp.
Aug 11, 2010 | NorStar M7208 Corded Phone
Redirect a caller to voice mail
1.goto phone menu.
2.goto setting.
3.goto callsetting.
4.goto divert call to voice mail
Jun 02, 2010 | RCA 25202RE3 Corded Phone
Unable to leave voice mail, says good-bye
I don't think the voice mail is going bad.
On my 4424D+, I can turn off voice mail.
I use this feature when I'm gone for an extended period of time so I don't come back to 100 VMs.
Dial into your voice mail.
Choose the prompt for Call Answer Mode. (Option 8 on my phone.)
Then choose the prompt for Record Mode. (Option 1 for me.) This allows callers to record voice mails on your line.
Feb 17, 2010 | Avaya 4412D Corded Phone
Cannot clear message on handset that says I have a voice message.
I resolved the problem but I'm not 100% sure of how I did it. If it happens again I'll try it again. I left the answering machine OFF so the Voice Mail would take any messages. A friend phoned and left a message in the VOICE MAIL, I knew this because of the broken dial tone when I went to make a call. When I erased his message the 'New Voice Message' displayed on the handset disappeared. I figure a previous caller hung up just after the voice mail picked up. It was not long enough so it did not register in the voice mail but somehow registered on the GE phone. Since there wasn't anything registered in the VOICE MAIL to erase the message was 'stuck' on the handset display. As soon as there was a message registered in the VOICE MAIL that could be erased it also cleared the message on the handset.
As i mentioned, if it happens again I'll try it to see if it works, until then I am not going to tempt fate.
Dec 24, 2009 | Uniden Cordless Phone
Simply set up voice mail? Callers get message
u need to call the carrier to have them cancel and reregister ur voicemail profile
Oct 07, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Recorded incoming voice mail message download
I called my telephone server of voice mail and they led me through process.
Aug 22, 2009 | Uniden Cordless Phone
GE 5.8 phone (dual)
You must have a recorded message on the answerer in order for the machine to record messages left by callers. I would bet that there are no messages there yet. It couldn't tell callers to leave a message if there is no message there. I know there is one standard one already there and the handsets often say NEW VOICE MAIL. If the round screen on the base unit has a number there, then you have a message and all you need do is push the play button.
Nov 09, 2007 | GE 25932 Cordless Phone
Going to voicemail
The phone you have can go on several different Norstar phone systems and you can have several different types of voice mail. Your voice mail (and possibly the phone system) needs to have programming changes, not the telephone. Your first step is to determine which Nortel phone system you have and also what model voice mail. You will need manuals for the phone system and voice mail. Hopefully you already have a programming or administration manual for the voice mail. Someone should have gotten this information when the system was first installed but that could have been many years ago.
What happens when you are waiting for that time? Do you hear absolutely nothing? Instead of being sent directly to your voice mail box, it may be sending callers to a voice mail branch where you would normally have a recording "press 1 for this, 2 for that" If there is no recording the system will wait for a response that the caller has no idea of and usually replay the message 3 times before defaulting to your mailbox (in this case a blank message). That is my best guess with the information I have from you so far.
Nov 01, 2007 | NorStar T7316E Corded Phone
Panasonic KX-T7731 Corded Phone Logo
51 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
