Sounds sarcastic but make sure the power point is OK. If you have checked everything you said plug, lead, switch, wiring and brushes then the only thing left is the motor field coils of the armature. One of these is open circuit. That is a winding has broken. Some you can see and or smell but otherwise a circuit tester is your only friend. If you find that one of these is at fault then the unit is probably not worth repairing. Cheers Bob
SOURCE: Rear cylinder not firing
95 Evo, new plugs, new wires, started backfireing like a machine gun, front cyl. no spark at plug sometimes - would this be the coil, have not ohmed the coil yet . Thanks
SOURCE: hi guys ...please help ...... i removed my plug
It goes to the coil of course but it is more than likely made into the coil and cannot be r replaced with replacing the coil. Call the Suzuki dealer and try to buy just the coil wire.
Good Luck
Testimonial: "i have another reply and they say that the coil comes in that fashion and it is not damaged ...it is a screw type lead ...it pushed back in ,,,,,is th"
SOURCE: firing order
If 1-4 coil does that mean it goes on 1-4 plug and 2-3 coil goes on 2-3 plug is right what does the firing order mean 1-2-4-3
