Question about Valor Apple iPAD i-Pad 3G, Wifi 16GB 32GB 64GB Tablet Slate Full Diamond Crystals Bling Back Protective Case Cover and Zebra Animal Skin Design
How to fix my iphone - disabled
Iphone 6 disabled
Posted by Roy Thigpen on
Abby Carter
    Guru:
  • 268 Answers
If your iPhone is disabled due to: Software Update Failed, iPhone Stuck on Verifying Update, iPhone Stuck in Recovery Mode, iPhone Stuck on Apple Logo , etc. You can try these fixes:
https://www.imobie.com/support/common-ios-10-problems-and-quick-solutions.htm
Posted on Sep 29, 2016
john h
    Top Expert:
  • 23,438 Answers
Either send in to a place for repair and diagnostics ---or if icloud disabled you bought a parts phone
Posted on Sep 27, 2016
My iPhone 6 is dsabled. How do I get my phone back
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apr 04, 2017 | Apple iPhone 6
How do i disable the passcode on a iPhone 6 plus with IOS 10.0.2.
You can't unless you do a factory reset, this wipes the phones memory clean along with the password or code.
Oct 06, 2016 | Cell Phones
My Iphone4 is disabled, windows and iTunes does not recognize it, I want to factory rest it.
How to Unlock/Fix a Disabled iPhone - "I forgot my iPhone ...
? 7:34
https://www.youtube.com/watch?v=DjEw6DPGYiY
Jan 7, 2015 - Uploaded by Full Screen Ahead
4.) While holding the circle button at the bottom of your iPhonedisplay, ... Your PC or Mac will say "iTunes has detected aniPhone in recovery mode. ... says "Are you sure you want torestore the iPhone to its factory settings?
How to remove/reset any disabled or Password ... - YouTube
? 5:31
https://www.youtube.com/watch?v=csLUmaDTHl4
Oct 30, 2014 - Uploaded by Karlos Corner
How to remove/reset any disabled or Password locked iPhones6S ... Thank you for watching, please feel free to comment, likethe video or subscribe to my ..... Iphone Disabled / Forgot Passcode iPhone Fix - Hard Reset for ...
Hard Reset for iPhone 6/5s/5c/5/4s - YouTube
? 3:21
https://www.youtube.com/watch?v=C8OCbVO8r6g
Jan 27, 2016 | Apple iPhone 3G
My iPhone has disabled how do I unlock it
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - If you enter the wrong passcode in to an iOS device six times in a row, you'll be locked out and a message will say that your device is disabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't ... If it doesn't, learn what to do. Once the sync and ...
How to remove/reset any disabled or Password locked ...
? 5:31
iTunes will alert you that it has detected a device in recovery mode. 6. .... easy and fast to activate/unlock/jailbreak/bypass every iphone from 5s to 6s without having any problems. use "newunlockiphone,net". .... +Clair Glen My iPhone is disabledfor 23,760,796 minutes. ... Do you need an ITUNES account?.
Top Ways To Unlock iPhone Disabled - YouTube
? 2:35
https://www.youtube.com/watch?v=KiWp28QTToQ
Jan 1, 2014 - Uploaded by CocTubes
How to Unlock Your iPhone When Its Disabled .... me use myfingerprints like it normally does. of anyone has anyway of helping.... What to do?
Dec 16, 2015 | Apple iPhone 4 Black Smartphone
How do I unlock my disabled iPhone 6?
there are so many tools for phone unlocking one of the best tool is https://www.unlockninja.com Unlock Your Cellphone Use Any Network in The World
Aug 12, 2015 | Apple iPhone 6
Just got iphone back it says its diabled but for 23,685,670 minutes?
How to fix it if your iPhone is disabled?
If your iPhone is disabled and has to be connected to iTunes, you can connect it to an authorized computer, and the Enter Passcode window will show again. If you insert the right passcode this time, your iPhone will be all right again.
If you forget the passcode completely, I'm afraid that the only way to make it back to work is to reinstall.
Note, that the iPhone will erase itself after ten incorrect password attempts in a row. You can turn this off under Settings > General > Passcode Lock.
6 attempts: 1 minute
7 attempts: 5 minutes
8 attempts: 15 minutes
9 attempts: 1 hour
10 attempts: Erase data. If that option is off it will require connecting to iTunes to unlock.
Mar 04, 2015 | Apple iPhone 4S
Iphone disabled for 6 million minutes! How do I enable it without restoring?
I tried to fix this on my boss' iPhone today. But I got the DFU timing wrong. Instead of doing pwr + home (15) home (10) I did pwr + home (10) and home (15). The iPhone booted up as normal! I cannot verify the exact steps as it is now fine. But give that a bash.
Aug 18, 2011 | Apple iPhone Smartphone
Valor Apple iPAD i-Pad 3G, Wifi 16GB 32GB 64GB Tablet Slate Full Diamond Crystals Bling Back Protective Case Cover and Zebra Animal Skin Design Logo
239 people viewed this question
Top Valor Cell Phones Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
john h
Are you a Valor Cell Phone Expert? Answer questions, earn points and help others
