Question about Rustoleum Rust-Oleum - 1685830 - Spray Paint, Galvanized, 14 oz
Spray can won't spray its a full can
Its a new can
Posted by yvonne welsh on
john h
    Top Expert:
  • 23,438 Answers
Either defective sprayer or no propellant either return or try different spray tip
Posted on Sep 27, 2016
1997 Chevrolet camaro windshield sprayers won't
I would check the washer pump to see if it is working assuming the tank is full of fluid.
Aug 24, 2012 | Cars & Trucks
Where is the fuel filter
The fuel filter is mounted on top of the fuel tank by 1 10 mm bolt. Remove this bolt (Spray some WD-40 on it first, so it won't break on removal). Then, squeeze together the plastic tabs at the ends of the fuel lines and pull the line(s) off. REMEMBER, THE FUEL IS UNDER HIGH PRESSURE AND WILL SPRAY WHEN YOU REMOVE THE LINES!!! KEEP ALL DROP LIGHTS AWAY FROM UNDER THE VEHICLE!!! You'll loose a couple cups full of fuel, be prepared!!. Also, when installing the new filter, put some motor oil on the lines prior to sliding the new fuel lines into place. This will prevent damage to the O-ring(s) in the new filter lines. Make sure the plastic tabs "snap" into place, try pulling on the filter line to make sure the clip(s) are engaged. And as Curious stated, you'll need to know the wheelbase of your van to get the proper filter.
May 20, 2012 | 1998 Dodge Caravan
I have through bolts stuck in rear spindle (knuckle). I have them removed from the car. I have been heating and spraying with WD 40. (day one) I let them take a 2 day bath submerged in PB Blaster, then...
seems like a considerable effort when the wreckers/junk yards are full of good units
may be the bolts are part of the rubber mouldings
have you tried a hydraulic press to push them out
Jul 15, 2017 | 2000 Dodge Neon
MY LIBMAN SPRAY MOP WON'T SPRAY AND ITS BRAND NEW. i FILLED THE CUP UP AND PRIMED THE HANDLE AND STILL NOTHING.
Did you ever get a solution? I just bought it today, and am having the same problem. I also sent an email to Libman.
Oct 11, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Dishwasher spray arm is not spraying water. the dishwasher fills with water put won't spray. could it just be spray arm or something else
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 25, 2011 | Tappan Dishwashers
IBM Wheelwriter 6781 won't perform a full carriage
Spray some WD40 on the silver shaft that the carrier slides on. If this doesn't work Spray some on the carrier motor bearings, located under the case R. rear corner. You can access the front one from 9inside the rear you will have to fish the straw thru the case.
DickyO
Aug 04, 2011 | IBM Office Equipment & Supplies
Framers 702xp won't drive a nail more than an inch into wood and sometimes won't retract the pin all the way.
Before you use the tool put a few drops of oil into the air line input. The pin may be sticking. You could try spraying WD40 into the area where the nail comes out also.
Sometimes dirt can build up in the region that the pin slides in and other moving parts and cause them to stick so you may have to dismantle the gun to clean it. Spray WD40 on all moving parts before re-assembly.
Jul 14, 2011 | Senco 2K0013N FramePro 702XP 2Inch ...
Car will turn over fine but won' start, as if it is starved for gas. the car is full and i have also checked the fuse for the fuel pump and it is fine.
but is the fuel pump working.if you remove the air snorkel and spray intake cleaner into the intake while someone tries to start the car and it starts then you have a fuel problem.either the pump,plugged fuel filter,fuel injectors not working,dirt in the fuel system.check the fuel pressure if it doesn`t start when spraying cleaner into the intake.
Jul 07, 2011 | 2000 Jeep Cherokee
Rustoleum Rust-Oleum - 1685830 - Spray Paint, Galvanized, 14 oz Logo
60 people viewed this question
Top Rustoleum Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Rustoleum Tool and Hardware - Other Expert? Answer questions, earn points and help others
