Question about Rustoleum Rust-Oleum - 1685830 - Spray Paint, Galvanized, 14 oz
Spray can won't spray how to fix
Its a full can and it won't spray
Posted by yvonne welsh on
The Vanguardian
    Master:
  • 531 Answers
Pull the nozzle straight up and out. Grab a nozzle from another can that looks to be the same and try that one. You may have to try multiple nozzles. You can also buy nozzles on ebay, but they are usually more than the price of the can.
If this doesn't work, then the can may be faulty, or if very old (many years) it may no longer have pressure even though there's still paint inside.
Another thing to check is if the ball inside rattles when you shake the can. If it doesn't, the paint might be hardened in the can.
Remember next time you finish painting to wipe off the nozzle, turn the can upside down and spray until almost no more paint is seen.
Posted on Sep 27, 2016
1997 Chevrolet camaro windshield sprayers won't
I would check the washer pump to see if it is working assuming the tank is full of fluid.
Aug 24, 2012 | Cars & Trucks
I have through bolts stuck in rear spindle (knuckle). I have them removed from the car. I have been heating and spraying with WD 40. (day one) I let them take a 2 day bath submerged in PB Blaster, then...
seems like a considerable effort when the wreckers/junk yards are full of good units
may be the bolts are part of the rubber mouldings
have you tried a hydraulic press to push them out
Jul 15, 2017 | 2000 Dodge Neon
IBM Wheelwriter 6781 won't perform a full carriage
Spray some WD40 on the silver shaft that the carrier slides on. If this doesn't work Spray some on the carrier motor bearings, located under the case R. rear corner. You can access the front one from 9inside the rear you will have to fish the straw thru the case.
DickyO
Aug 04, 2011 | IBM Office Equipment & Supplies
Framers 702xp won't drive a nail more than an inch into wood and sometimes won't retract the pin all the way.
Before you use the tool put a few drops of oil into the air line input. The pin may be sticking. You could try spraying WD40 into the area where the nail comes out also.
Sometimes dirt can build up in the region that the pin slides in and other moving parts and cause them to stick so you may have to dismantle the gun to clean it. Spray WD40 on all moving parts before re-assembly.
Jul 14, 2011 | Senco 2K0013N FramePro 702XP 2Inch ...
Car will turn over fine but won' start, as if it is starved for gas. the car is full and i have also checked the fuse for the fuel pump and it is fine.
but is the fuel pump working.if you remove the air snorkel and spray intake cleaner into the intake while someone tries to start the car and it starts then you have a fuel problem.either the pump,plugged fuel filter,fuel injectors not working,dirt in the fuel system.check the fuel pressure if it doesn`t start when spraying cleaner into the intake.
Jul 07, 2011 | 2000 Jeep Cherokee
My Spray-Doc sprayer won't hold pressure any longer. What should I do to fix it.
I would see about getting a gaket kit which they sell and will have no seals and O-Rings in it for the fill cap and the spray tip.
May 08, 2011 | Garden
I have a ford f350 duelly and it wont start but it will turn over i have jump started it and it started and now i have had it pluged in for 2 days and it still wont start plz help me figure it out
If its a diesel then you may need to get a spray can of ether starting fluid. Spray this directly into your air filter housing for approximatly 3-5 seconds. Try it once then try to start your truck. if it doesnt work then have someone else spray it in while you turn it over. However your problem maybe that you dont have enough charge in your batteries to completely turn your engine over to get full compression. in this case charge your batteries and try again.
Feb 04, 2011 | 1991 Ford F350
Rustoleum Rust-Oleum - 1685830 - Spray Paint, Galvanized, 14 oz Logo
81 people viewed this question
Top Rustoleum Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Rustoleum Tool and Hardware - Other Expert? Answer questions, earn points and help others
