no PC stated (you are posted to computers and not CELL phones)
NO OS stated at all windows/ y/n if yes, which one W10?
NO DEVICE STATED, USB. (vast and endless this)
are you sure BT works on this unstated PC.?
most old PCs it was an option on laptops. very common..
IF BT works on other devices say so and do so. first.
or run HWinfo32.exe portable and free to see if the BT port option is even there at all. inside unstated PC.
Bluetooth® profiles In order to use Bluetooth® wireless technology, devices must be able to interpret certain profiles. This unit is compatible with following profile. A2DP (Advanced Audio Distribution Profile)
Are your devices A2DP compatible? If yes, please comment below with model no. and I'll assist further.
what browser are you using ??
copy address from bar of page you want
close all other tabs
go to browser settings
find homepage settings paste the copied address or press use current page button
save settings
close and restart browser
To do a hard reset for LG soundbar las450h or 550 series, long press the volume min button on the soundbar and sound effect button on the remote simultaneously for 10 secs and the soundbar screen will show reset mode. Switch off and switch on the soundbar.
If your soundbar has bluetooth technology in it, turn it to the input of "Bluetooth" or "BT". In your TV's smart menu, you should be able to find bluetooth settings, and be able to find the soundbar from there. If you are looking to connect it by a cable, you will have to connect a digital optical cable into the back of the TV, and run it down into the soundbar to receive sound out of it.
Here is what the sensor normally means, It's a map/tps sensor correlation code, essentially it means the map
sensor reading isn't what's expected with the tps reading and vice
versa! It sounds like your tps sensor is probably bad or the circuit to
one of those 2 sensors.
I see that you need assistance in getting your BT heatset to your LG phone.
make sure that the BT headset is set to discoverable mode, I believe there is a connect button on the headset that you can press and hold down for a couple of seconds this should lit up a light meaning that the BT headset is ready to be discovered by a device.
Once the Headset is set to be discoverable you can try and get you LG phone to detect the headset, Once detected the pairing code should be standard try 0000 this should get the BT headset connected to you LG phone.
