B
Bonnie armer Posted on Sep 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to redo the phone answer recording on my cannon fax phone 845
Reset answer message
Stan Ford
Level 3:
Genius:
  • Master 3,131 Answers
  • Posted on Sep 27, 2016
Stan Ford
Master
Level 3:
Genius:
Answers
3131
Questions
Helped
903963
Points
9078
Instructions will be in the user manual , as each model differs, and if you no longer have the manual, Google Cannon . com for a user manual or instructions.
1helpful
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
How do I take a user off of the samsung phone system that just left the company and how do I redo the directory recording on the main message
Perform a factory reset to clear the phones info the logon to the phones website to reset the voicemail
I JUST NEED TO REDO MY GREETING
If it is not an answering machine, the greeting is part of your phone service. Call the number you use to get your messages. Listen for choices other than listening to messages. You want to listen for setup, settings, or similar menus and change "outgoing message" or "greeting". Make sure you listen and then save it if you like it, or re-record if you do not.
How do I tell my 2820 to prepare to receive an incoming fax? My phone line and my fax line are the same number. It continues to ring but the fax machine is not answering. I have also turned the answering...
To have the machine answer faxes and record voice messages unattended change the answering mode to message centre. If you are home and pick up the phone , but it is a fax, not a phone call push *91 on the phone you answered on, and hang-up the phone. the fax machine will tyhen start receiving.
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Reset outgoing message
Press and hold the ANNOUNCE button on the base and keep pressing it until you finish your announcement. Start recording your announcement when you hear a beep. Let go of the ANNOUNCE button when you're done. You can record up to a two minute message.
You can download the full manual here for future reference.
I HAVE A CANNON PIXMA MP830 IAM USING A ANSWER MACHINE ON MY PHONE I HAVE MY CANNON PIXMA ON "ANSWER MACHINE CONNECT" MODE SETTING BUT WHEN A FAX IS SENT TO ME THE PHONE RINGS THE ANWSER MACHINE...
the connection should be phone cord to the fax then to the answering machine. answering machine answers first (rings to answer must be lower than the fax).
To record a new message on my Sharp UX 265
press OGMn key
select O x general outgoing message
pick up handset and record your message (max 60 seconds) (best 30 seconds
recommend pause 2 seconds before starting recording.
press stop when finished.
press OGM to listen to recorded announcement. redo as above if not happy w it.
Cheers
[email protected]
Top Cannon Office Equipment & Supplies Experts
NOEL
NOEL
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
