Chevrolet 1993 Chevrolet 1500 Pickup Radio Logo
n
noah davis Posted on Sep 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO UNSTICK THE INTAKE MANIFOLD ON A4.3 LITRE 93 CHEVY i can,t pry it off.
I.ve pryed beat and banged and it want come loose without damaging it
john h
Level 3:
Top Expert:
  • Chevrolet Master 29,492 Answers
  • Posted on Sep 27, 2016
john h
Chevrolet Master
Level 3:
Top Expert:
Answers
29492
Questions
0
Helped
7546967
Points
193431
Might have been worked on before and someone applied gasket sealant find spot where it moves up a little and using a thin knife or scraper start moving blade into gap cut to break seal very carefully
2helpful
Can not remove lower intake manafold
many times the intake won,t just lift off.sometimes you must use a pry bar to lift it up.you must put the pry bar under the edge and carefully pry it loose but be careful not to break the edge.i assume you double checked to see if you missed a bolt.good luck.
2003 silverado 4x4 5.3L oil sensor location
Left rear side of intake manifold. Usually silver in color with plastic cap on top of sensor with 2 wires attached to black cap. Cap had plastic clip that needs to be pryed loose. Caps pull straight up when clip in loosened.
1helpful
Can't remove wheel
take a hammer or sledge and beat on the tire NOT THE RIM in a X rotation. wheels are probably aluminum and get oxidised onto the hub. as long as you hit the rubber tire you will not damage the wheel. It might take several minutes of banging on it to get it loose. when you are going to reassemble the wheel and hub make sure to wire brush the hub and wheel clean then take some Antiseize and put a nice amount around the hub where the rim makes contact that will help it do not happen again
How do you fix a knox sensor on a 2003 chevy silverado HD 2500 6.0 litre
It has two of them. Sorry to say that they are under the intake manifold and you must remove the intake manifold to gain access to them.
How do you remove the upper intake manifold for a '97 chevy1500, 5,7? all bolts are off, wiring harnesses disconnected, fuel line disconnected at rear bracked. Manifold slides around but will not let...
If all bolts are off take a screw driver and find a spot where you can pry the intake off the heads and block. The get pretty stuck to the gaskets and sealer after a while. Pry in as many spots as you can to distribute the pressure and lift it as evenly as possible.
2helpful
Changing head gaskets
If you are referring to the intake manifold, be very certain that you have removed all of the bolts from the upper and the lower intake manifolds. Here are some diagrams that might be useful to you.
If you are certain that all of the bolts are removed from the manifolds, then you can break the seal holding the intake manifold by using a large screwdriver, wedge it between the intake manifold and the cylinder head and you should then be able to pry up the intake manifold and get it to break loose.
You did not specify what engine you had so these diagrams are for a 1998 3.8 litre V-6 engine. I hope that they will be of any use to you.8d58a40.gif97f8120.gifc0dadb4.gif332b28c.gif0f0a8e9.gif
How do I change a in take manifold gasket in my chevy lumina?
remove the throttle body,remove the valve cover,remove the intake manifold bolts. you SHOULD be able to GENTLY pry the intake back enough to remove the gasket. be careful as to not scratch or ding any surface that comes into contact with the gasket.clean the gasket surfaces thoroughly and install the gasket. install in reverse order. make sure that you torque all bolts down to specs and in the order called for. on a final note...yu may have to remove the EGR valve to get some clearance to make it easier
2answers
How do i change an intake manifold gasket in very easy terms it is for a 1990 Chevy suburban Scottsdale?
You unbolt the intake manifold, remove the old gasket, install a new gasket, and bolt the maniforld back on.
You may have to remove sensors or hoses that block removal of the intake manifold.
you'll need a torque wrench when you bolt the manifold back on
2answers
Separating the drive axle from tranny on a 94 chevy cavalier
Hi, you need to apply some presure to it but it will come out ,try a pry bar , C1
Motor problems
pull the valve cover and pry the valves dont but do not force. you can use some WD40 and spray and try to get it loose
and if it doesnt come loose your that much closer to removing the head
Top Chevrolet Audio Players & Recorders Experts
Arnie Burke
Arnie Burke
Stan Ford
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
