La Crosse LaCrosse Technology Wireless Weather Station Logo
L
Lanny Perkins Posted on Sep 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset wind insrument - La Crosse LaCrosse Technology Wireless Weather Station
Marvin
Level 3:
Top Expert:
  • La Crosse Master 85,242 Answers
  • Posted on Sep 26, 2016
Marvin
La Crosse Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29037639
Points
266281
Remove the battery for 5 minutes.
Instrument cluster light wont turn on.
if your speeking of none of the insrument light illuminating, but headlghts work, then it's the headlight switch that's bad,the headlights will go out very soon though, it basiclly stages down, partial burnout starting with insrument panel. not too hard to change though. abt 50 bucks for the switch give or tk a few
2answers
What to do when your TI-30XA texas insrument wont turn on?
Try replacing the batteries.
Here's the official word from TI on replacing the batteries on the TI-30XA.
2000 mitsubishi eclipse speedometer works off and on?
check the connections from your Vehicle Speed Sensor to the insrument cluster. also check for any codes it might just be your vss
2answers
Insrument panel loses power periodically
this is just a loose fuse or connector wiggle the connector of the lighting control module just above you gas pedal under the dash.turn lights on try to kick slightly the module(black metal box).Sometimes you need to open it and re apply heat and solder on the relay terminals fixed on the board.
Speddo is stuck on 20mph does not give correct reading
gm had various problems with insrument panel, there was a recall on this problem.new instrument panel is very expensive try finding a used one
None of the instruments work on my 2000 F450; Gauges, Speedo, Odometer, etc. Ideas?
Check And See If The Fuse For The Insrument Cluster Has Not Blown Its In The Fuse Panel
TEMP GAUGE NOT WORKING ON 95 SONOMA 2.2
check the wiring insrument cluster to the temp sensor. check the ground wire.
Top La Crosse Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
