Question about Watches
How to get casio sea-pathfinder working after replacing batteries
The "BATT" came on and I replaced the 4 batteries. On the back of the watch on the inside it says "After battery replacement contact AC with battery (s) using tweezers"
Please explain this to me.
Thank you
Posted by pmcclain on
  • watchless Dec 16, 2008
    Casio WS 300 doesn't work after battery change. Don' know what AC is. Back of cover says to contact AC with battery + using tweezers
  • marysblues Jan 19, 2009
    i can't get my battery to work. the sticker on the old battery said to short circut the new battery with tweezers. what does this mean
BFH2
This certainly put me on the right track,but i found on my pathfinder mod 2271 that the four brass dots located down in the hole were unacessable with standard flat head tweezers so I inserted a small sewing needle and touched one of the brass dots while bridgeing the distance from the needle to the positive (+) surface of one of the four batteries with tweezer legs.
Posted on Apr 30, 2008
Anonymous
Got a sea pathfinder and just got it back after sending it away to get batteries replaced. Worked fine for a day or two but now none of the buttons work at all - it is still chugging along keeping the correct time but no buttons including the light works - is there a manual reset procedure without taking the back off?
Cheers
Daz
Posted on Sep 03, 2009
Anonymous
    New Friend:
4 X SONYhow to get casio sea-pathfinder working after repl - noavatar_s.gif>
Posted on Mar 10, 2010
Anonymous
Thank
Posted on Aug 24, 2008
Anonymous
On my older pathfinder the AC arrow pointed to a hole in the white plastic shield below with 4 "brass" dots. Connecting these to one of the batteries in place restarted the watch.
Posted on Mar 24, 2008
Anonymous
I have a old PAT-400 pathfinder and was trying to figure out how to get the watch working again after that battery replacement. Seen your post and noticed I had the AC text stamped into the internal plate. If you look at the circuit board above the text there should be two contacts. Use something to short them "tweezers". After that it reset and I'm happy again.
egg
Posted on Nov 29, 2007
How do i do this.After battery replacement, contact AC with (-) using tweezers
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Sep 19, 2014 | Casio wave ceptor WV200A-1AV Wrist Watch -...
Tried to change batt. in casio dv 39 1590 easy recrd watch recording not activated
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs///
Jan 07, 2014 | Casio Watches
Fossil es2157 replaced battery; but will not restart
you need to Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Dec 25, 2013 | Fossil Stella Quartz Stainless Steel Watch...
I just replaced the battery in my Nooka Zub Zen-V, now the display just flashes nonstop. I have tried pressing all four buttons for up to 30 sec. and the entire display turns on but when i release any of...
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.Shortcut battery with AC contact. AC can be found on the sides of watchlb_icon1.png movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs...
Oct 16, 2013 | Nooka ZOT V - White Face - White Strap...
JSprings Movement, Seiko VF62, battery change
Jan 22, 2013 | Watches
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
Casio module 2273 battery change
did u ever figure out how to get the retaining clip?
Mar 13, 2010 | Casio PRG-40T-7 Pathfinder
I just replace the battery for a casio watch 2315 but it still does not work
Hi, I just encountered the same problem today as I was changing the battery and I found the solution. First make sure when you are changing the battery that the watch stem is pulled out; then after the battery has been replaced, and before you put the gasket and back on you will need to "reset" or "hotwire" the battery ....you are going to likely need a magnifying glass to find a tiny ac symbol on the back of the watch (without the back cover replaced)...just next to the ac symbol is a tiny hole. Take a piece of wire, or in my case I used an unfolded paper clip, and put one end of the wire in the hole and the other end on the back of the battery (the +/positive side should be facing up). Leave the wire in contact with the ac/battery for 5 seconds, then remove. Next replace the rubber gasket, then the back and the screws. Lastly, push in the watch stem. Your watch should now work. I found out through considerable research that almost all digital watches will need that "hotwiring" step performed after the battery is replaced.
dcraigpa
Dec 21, 2008 | Watches
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
May 31, 2008 | Timex Advanced Data Link 53722 Wrist Watch
Watches Logo
2,380 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
