Ovens Logo
Question about Stoves Ovens
Can you e mail me the manual for Stoves precision 1100 cooker
Posted by Mrs M Fort on
Bill Boyd
    Top Expert:
  • Stoves Master
  • 53,816 Answers
No
go google and type in--- user manual for stoves precision 1100 cooker --- and download the pdf version your self
Posted on Sep 26, 2016
Moved house no manual to stoves cooker model 4444451 72oef
You will need to post an email address and then i will send you a pdf copy of the handbook.
Can I download a Manual for a Stoves 61EDO cooker. I am specifically wanting to know how to use the timer. Thanks
I have posted how to use the timer on the 720 on other solutions. Try that to see if it works.
3answers
Lost manual
Hi,you can download the manual for your unit for free at;www.manualsonline.com or www.manualnguide.com.
Thanks and take care
2helpful
3answers
Need instruction manual for stoves heritage 720EF cooker
Supply an email address and I will validate it on my BT Digital Vault to give you access to take a copy of the Handbook.
I have just got a new stoves cooker and i need the manual for it, the model number has worn away a bit but from what i can see this is the model number 039850512
If you contact STOVES with that number, they should be able to help you. If you want a copy of my 720EF manual, supply an email address and you can gave a copy.
Manual for cooker
just wondered if u ever managed to get a manual for the stoves new home 600 si dlm ? if so,could i be cheeky and ask u to email me a link please?
thx in advance :)
Ant
[email protected]
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Open Questions:
0answers
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Top Stoves Ovens Experts
Marvin
Marvin
Narseman
Are you a Stoves Oven Expert? Answer questions, earn points and help others
