You can always check out this troubleshooting guide, it should give you an overall overview of the situation and help out:
Common Bosch Dishwasher Problems And Solutions
SOURCE: We are working on a
Hi, well all this information is in your manuals, accordingly i include a link for your service manual, below.
http://appliancejunk.com/forums/index.php?topic=2933.0
Below is a link, to obtain your user and install manuals too...
www.apdappliance.com/products/Whirlpool/whirl/du915pwss
Below are a couple of helpful links too,
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208557727.pdf
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/3976dc6fea92e1c385256fc4006611c9?OpenDocument
SOURCE: A few days ago our
Hello Micheal,
The F4 error code refers to a filling error on that dishwasher.
Did ya accidently turn off the water supply the otherday while clearing the drain on your disposer,the reason i ask that the not filling and the humming to me sounds as if the water valve is on and humming and calling for water yet it has no water coming to it. A humming sound on the water valve is normal its the sound of the soloniod that opens it to let the water flow..the reason ya dont hear it when the water is filling is because the sound of the flowing water muffles the hum.
Check that the water flow is good into the dishwasher and the line isnt perhaps pinched or kinked somehow
GEEN
SOURCE: bosch dishwasher model shu43c05uc diagnostic code C1 at start then P0. what does this mean?
You seem to have inadvertently put it into the test sequence. Try pressing the two reset button simultaneously (usually the reset buttons are 1st and 3rd from left each with a dot underneath, if this does not work, press the button between the two resets (2nd button) P1 should come on then press the right reset button. The unit should run through a test cycle for approx 20mins and eventually reset the module, this is indicated by 0 in the display. Please repost if further assistance required.
